Core 2 Duo Pricecut [40% OFF] + E4xxx pricing info
http://www.hkepc.com/bbs/itnews.php?tid=714230&starttime=0&endtime=0
In the past, AMD once won the performance battle with Intel by its innovative and excellent processor micro-architecture, and then Intel got back the leadership by the introduction of its new Core architecture. From this history, instead of clock speed and FSB, we know micro-architecture really does matter to the performance race. With improved micro-architecture, AMD will release its next-generation AM2+ processor in Q3 2007, trying to make a fight with Intel Core 2. Due to this reason, Intel just released the companys plan on Core 2s price cut to maximize its combat efficiency in the battle, in which Intel Core 2 Quad has a noticeably price cut of 40%.
The upcoming rivals, AMDs Agena (formerly codenamed Altair) and Kuma (formerly codenamed Antares) have already put in schedule to be releasing in Q3 2007. The new micro-architecture has lots of improvements includes : Hyper-Transport 3.0 (from 2GT/s to 5.6GT/s), 32B Instruction Fetch, more precise Branch Prediction and Out-of-Order Load Execution, 4 Double Precision FLOPS/Cycle, Dual 128Bit SSE calculation, and Load per Cycle. Once AMD has told to the market that the new micro-architecture was hopefully will get back the performance leading which is now owned by Intel.
As the threat arises, Intel has decided to take a remarkable price cut to minimize the risk in the market. This plan included a huge price cut to Intel Core 2 Quad and Duo models. One of the most noticeable cut, Core 2 Quad Q6600 (2.40 GHz/4MB L2 x 2/1066MHz FSB), which is going to launch on Jan 7 2007, is planned to be cut from $851 to $530, a 37.7% off. Meanwhile, Core 2 Duo E6700 (2.66 GHz/4MB L2/1066MHz FSB) and E6600 (2.4 GHz/4MB L2/1066MHz FSB) is planned to cut from $530 and $316 to $316 and $224 respectively, a 40.3% and a 29.1% off.
Over and above, though Core 2 Duo E6400 (2.13 GHz/2MB L2/1066MHz FSB) and E6300 (1.83 GHz/2MB L2/1066MHz FSB) havent got too much cut in this plan, says from $224 to $183 (18.3%) and from $183 to $163 (10.9%), Intel would like to give a special gift to this models, a 2MB extra L2 Cache (total 4MB L2 Cache). These 4 MB L2 Cache versions, namely Core 2 Duo E6420 (2.13 GHz/4MB L2/1066MHz FSB) and E6320 (1.83 GHz/4MB L2/1066MHz FSB), are going to launch on the same day of price cutting.
In addition, the previously planned Intel Core 2 Duo E6390, which does not support for VT, has been cut in the future plan.
On the entry-level dual core market, besides Intel Core 2 Duo E4300 (1.8 GHz/2MB L2/800MHz FSB), which will be launched on Jan 21 2007, there is another E4400 (2 GHz/2MB L2/800MHz FSB) coming in Q2 2007 set at a price of $133. On the day of E4400s launch and onward, E4300 will has a new price from $163 to $113, a 30.7% off.
As an Intel expected, Intel Core products is hopefully exceed 50% of the total shipment during Q2 2007, making a crossover to the previous-generation product. Since Pentium 2000 and Celeron 400 family are going to release in Q3 2007, its expected that the shipment share would further increased to 80%.
  • תגובות 107
  • צפיות 11.7k
;D
:yelclap:
מתי נרגיש את הירידה בארץ?
אז מרובעי הליבה כבר יהיו אפשריים מבחינה כלכלית, מעניין אם שווה להשקיע באחד במקום כפול ליבה?
מעניין מתי מחירי כפולי הליבה ירדו בארץ, אני מתכנן לקנות אחד...
כנראה שרק ברבע השני של 2007
איזה ביאוס שקניתי מחשב לפני יום
יכול להיות שאני מריח ריח של שדרוגים ?
אאאח איזה קיץ חם הולך להיות....
רגע.. הבנתי נכון!? המחירים של הC2D הולכים לרדת ב40% :smile1:
או רק לכמה דגמים?!
או אם בכלל?!
תודה לעונים!
הכל כתוב,תקרא תבין.
4300E הולך להיות מעבד פצצה!! רק 113$ !!!
113$ לE4300!
על זה אני מזיל ריר(אם אכן הוא אוברקלוקר טוב כמו שמתוכנן)
ב2500-3000 ש"ח יהיה אפשר לקנות חיית אוברקלוק.
אין הרבה מה לתת תקציר ,רק שהירידת מחירים תחל ברבעון השני של 2007 (זאת אומרת מסוף מרץ-אפריל) יש מצב בגלל ההכנות בAMD ל K8L?
שלושה מעבדים חדשים מוצגים לראשונה: E4400, E6420 ו E6320
כתוב עליהם בטבלה :
אינטל שיחקתם אותה!!!
*אורי אפשר לראות שE6600 יורד למחיר של E6400 כיום (רמיזה להבטחה ;D)
מקור:
:xyxthumbs:
רק מה ההבדל בין ה E ל Q ?
Q- מעבד מרובע
E -מעבד כפול ליבה.
ד"א לא שמתי לב שיש כבר דיון על זה:
http://hwzone.co.il/community/index.php?topic=226108.0
אם אפשר לאחד את שניהם? או לעשות משהו במצב.
לא שמתי לב פשוט :-[
חתיכת הורדת מחירים, רק חבל שזה לא לעכשיו.
E6320 ו E6420 הם מקרים מיוחדים שכל ה Cache בריא אבל המעבד לא מחזיק מהירות שעון גבוהה ואינטל רוצה לעשות על זה עוד קצת $$, נחמד.
עריכה:
הממ בעצם הם לא מוסיפים $ אחד על הוספת ה Cache, עוד יותר נחמד - אבל לא ברור לי למה עם זאת הם משאירים את ה E6400 וה E6300...
כנראה יותר מתשלם להם לתת מעבדים עם 4MB שלמים מאשר 2MB מבוטלים.
והם רוצים לחסל את E6400 ו E6300.
נראה טוב...
אבל יש לי כבר E6600 ;D
אז לי אין סיבה לחכות 8 חודש להורדת מחירים.
האמת מי שרוצה לקנות היום מחשב אין לו גם סיבה לחכות כל כך הרבה זמן.
