עזרה בהתקנת סורק שקופיות של ניקון coolscan 3 ls
אני לא מוצא דריבר שמתאם לי את הסורק ל XP
http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00B5Fg&tag=
I'm not so sure that there is a 'driver' as such for the LS-30, it's controlled by an application via the SCSI interface, this can be the NikonScan software or Vuescan. How is your SCSI set up, this will need drivers for the SCSI card, and you'll need something called ASPI, which is a layer between XP & SCSI to be able to communicate with the LS-30 under XP. If the SCSI set up is correct the systen should be able to 'see' the LS-30, without any driver being present.
Another thing is that the LS-30 requires a firmware update to be able to use NikonScan 3+, this is also available from Nikons web site.
So you need to give a few more details about what you can & cannot do. Does the systen see the scanner in device manager? Do you have ASPI installed ? Once you can see the scanner you should be OK, try downloading the trial of Vuescan & see if that can operate the device.
