Awesome new system, poor performance
Thanks to the great people here I've purchased a new computer a few days ago:
Sapphire Radeon X1900XT 256MB
Intel Core 2 Duo E6300
Western Digital 2 RAM 667MHz
Gigabyte 965P-DS3
kitzer, sus. I have WinXP, with service pack 2, .NET Framework and all newest drivers installed, but I still get ridiculously low results with 3DMark2005 (almost always below the 20FPS mark, and a constant 0 (!) in the CPU test).
I bought it from KSP, and I'm pretty sure they're reliable. I have no idea what the hell is wrong, so help would be very much appreciated... thanks.
בדקת במשחקים איך זה פועל?
KSP לא חנות אמינה במיוחד, בניגוד למה שאמרת.
I ran an old game, Battle Realms. Not very graphically impressive, but frame rate still drops during action on 1024 res.
Is there any program that can specifically identify hardware? (not the GPU series but the specific model)
התקנת את כל הדריברים?!?! :silly:
Yes. I have the newest Catalyst 6.11, all motherboard drivers installed from disc, service pack 2... everything :\
(I Installed .NET Framework after installing Catalyst, but I dont think it makes much of a difference...)
תנסה במשחקים טיפה יותר חדשים....
אם לא :(
תבדוק את הכרטיס?
אם הבעיה לא בכרטיס אז פירמוט!
eich ani amur "livdok" et ha kartis?
i formatted once alredy. before that i only ran 3dmark2001 and got 28000 (That's pretty poor, I think)
DAMN!
לא יודע תילך לחנות שיחליפו לך תכרטיס...
Like I said Sapphire Radeon X1900XT.
To replace it? On what grounds? I mean, the card works and there are no actual problems per se
יש לי רעיון...
תדבוק את הכרטיס אצל מישהו אחר \חבר חמממ ...
תנסה להריץ משחק יותר חדש, DM,Oblivion ושות'.
תריץ super pi.
תחזור אלינו עם התוצאות.
I ran Super Pi. 30.279s for a million digits.
I'll try playing a new game tomorrow, but I'm not optimistic...
אם הכל חרא תנסה להפעיל את הכרטיס במחשב אחרר......ררר.ררר :sleep:
Is the Super Pi result decent for E6300? I don't think this program is very graphically advanced:)
to see how it works at friends'... sipur. I'm not sure if I could attach the card back :\
