-solved-an odd issue with Aterm on Arch
well, i just just dont get it really, maybe you will.
been using Aterm for ages, really, and suddenly after i installed arch+E17, i see to my surprise that aterm doesnt accept any command line arguments to start it.
that is, i cannot configure colors, fonts, or transperacy on it' even though im using the same options i have for years....
its not E17's issue, that much i know, been tested and worked on a gentoo+E17.
anyone have any idea?
arguments are
aterm -title 'Arch terminal' -tr -shading 45 -fade 60
nothing too complicated, i dont see any reason why it shouldnt work.
sorry for the english, didnt add hebrew here yet, but i can read hebrew...so reply at whatever language you want
EDIT:solved. somehow Esetroot didnt register the background till after i re-logged in and tried again. odd indeed.
