איך המסך הזה: Samsung SyncMaster 204B Black 20.1 LCD
איך הוא??
למישהו יש ניסיון איתו?
הנתונים היבשים הם:
Panel Type: a-si TFT/TN
Viewable Size: 20.1"
Pixel Pitch: 0.255mm
Brightness (Typical): 300 cd/m²
Contrast Ratio (Typical): 800:1
Viewing Angle (H/V, Typical): 160°/160° (CR>5)
Aspect Ratio: 4:3
Interface: Analog/Digital
Response Time (Typical): 5 ms
Native Resolution: 1600 x 1200
Maximum Color: 16.7M
Input Video Signal: Analog RGB, DVI Digital Link
Sync Type: Separate H/V, Composite HV, SOG
Input Connectors: 15-Pin D-Sub, DVI-D
Power Consumption: 36 Watts (max)
VESA® Wall Mount: 100 mm (optional)
Emission Standard: TCO '99
Bezel Color: Silver
Dimensions: 17.5x16.8x7.9 (WxHxD) inches (w/stand)
Weight: 16.9 lbs
Special Features: Narrow bezel, rear main power switch, Magic Tune with asset management, MagicColor, Magic Bright, and Magic Speed.
Warranty (P/L/B): 3/3/3 (years)
