בעייה בצורב לוג בפנים
[YAMAHA CRW3200E
8:41:48 PM #14 Phase 24 File dlgbrnst.cpp, Line 1571
Caching of files started
8:41:48 PM #15 Phase 25 File dlgbrnst.cpp, Line 1571
Caching of files completed
8:41:48 PM #16 Phase 36 File dlgbrnst.cpp, Line 1571
Burn process started at 24x (3,600 KB/s)
8:41:48 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 1948
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
8:41:48 PM #18 Text 0 File Mmc.cpp, Line 17168
Set BUFE: supported -> ON , Optimum Writespeed Control : ON
8:42:10 PM #19 SCSI -1106 File Cdrdrv.cpp, Line 1381
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02760000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
8:42:10 PM #20 MMC -1106 File Writer.cpp, Line 335
Power calibration error
8:42:10 PM #21 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
8:42:10 PM #22 CDR -201 File WriterStatus.cpp, Line 188
Invalid write state
8:42:10 PM #23 TRANSFER -18 File WriterStatus.cpp, Line 188
Could not perform EndTrack
8:42:10 PM #24 SCSI -1026 File Cdrdrv.cpp, Line 1177
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x2C 0x04
8:42:10 PM #25 MMC -1026 File WriterStatus.cpp, Line 227
Current program area empty
8:42:10 PM #26 TRANSFER -19 File WriterStatus.cpp, Line 227
Could not perform Fixation
8:42:10 PM #27 Text 0 File WriterStatus.cpp, Line 236
falling back to disc fixation
8:42:10 PM #28 SCSI -1026 File Cdrdrv.cpp, Line 1177
Sense Code: 0x2C
Sense Qual: 0x04
8:42:10 PM #29 MMC -1026 File WriterStatus.cpp, Line 227
8:42:10 PM #30 TRANSFER -19 File WriterStatus.cpp, Line 227
8:42:10 PM #31 Phase 38 File dlgbrnst.cpp, Line 1571
Burn process failed at 24x (3,600 KB/s)
8:42:10 PM #32 Text 0 File Scsicmd.cpp, Line 402
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
שלום גם לך ??? ??? ???
idd, לא צריך להגיב אם אין לך משהו רלוונטי לומר.
הייתי עושה ציטוט ;D
בקיצור נסה לכתוב אל סוג מדיה אחרת אם זה עושה את אותה הבעיה נסה לשדרג FIRMWARE
של הצורב.
אם כל זה לא עוזר והצורב באחריות תחליף אותו.
היה לי את זה פעם לי עזר אם אתה לא יודע אך מה אני מדבר ויש לך אחריות אז אל תבזבז את הזמן שלך תחליף וזהו.
אתה יכול בבקשה לתת לי לינק לפירמוואר חדש? רשום למעלה ת'דגם
תשמע הFIRMWARE האחרון הוא 1.0D
הנה הקישור:
http://www.yamaha.co.jp/english/product/computer/engfirm/a3210d_e.exe
לפי הדגם שאני רואה אצלך הצורב אמור להיות עוד באחריות אם כן למה לך לשבור את הראש תחליף אותו לזה נועדה האחריות. ;D ;D ;D
ושוב האררור הקלאסי... calibration error
יכול להיות כתוצאה מספק חלש? :P
תשמע לגבי הCalibration אכן יכול להיות שהספק לא חזק מספיק אבל לפי מה שאני רואה אצלך בלוג מדובר ב cannot perform fixation.
ובכל המקומות ממליצים שני דברים .
1. לשדרג FIRMWARE
2.לשנות סוג מדיה שאתה צורב אליה הכוונה לחברה של המדיה כי לא כל הצורבים עובדים טוב עם כל המדיות ישנן מדיות שמומלצות.
תנסה לצרוב אל מדיה איכותית כמו VERBATIM ותגיד אם יש את הבעיה.
סבבה למה כי אני צורב על כאלה אנונימיים 8)
