advice about AGP cards -about $100
Hello,
I have a computer for 2.5 years, and I want to upgrade my graphics card a little, just so I can hang on to this computer for 2 more years, and then I'll buy a much better system (dual core etc..)
What I have now:
Motherboard: Abit NF7-S (version 2)
CPU: AMD Athlon 2600+
Memory: 1024
Graphic card: Sapphire Radeon 9600
I found a medium price card for $99 (canadian): Sapphire ATI Radeon X1300 256MB DDR DVI-I TV-Out AGP 8X
What do you think? Should I get it, or another one, or maybe I should just wait until I buy a new system in about 2 years??
Is it much better than what I have?
THANKS!
No its not much beter than what u have
try to find a second tire card, something used and beter than the one u have
u should get it cheaper then
Hi there,
wellcome to HWZONE
Oren,from where would you like to buy the video card?
You should go for a 6600 card if u want a real improvement
hi welcome to the forum
first of all if you can tell from where are you will be great
and also can you tell how much would you like to pay for the graphic card so we can match one for you
Please state your budget in the thread's topic.
If you didn't guess, I'm living in Canada right now, but you can also guess from my name that I'm Israeli, so you all can write in Hebrew if you want...
As I mentioned, I want to give a "little" upgrade to my computer. I don't want to spend a lot of money, because I will buy a new system in about 2 years. I want to spend $50-$100.
The websites I use for the stores here are mostly:
www.tigerdirect.ca
www.factorydirect.ca
http://www.canadacomputers.com
Right now I have:
CPU: AMD Athlon 2800+ (TIKOON TAOOT from before), ~2.1GHz
Memory: 1024
Graphic card: Sapphire Radeon 9600 Atlantis AGP
I found on canadacomputers.com this card: Sapphire ATI Radeon X1300 256MB DDR DVI-I TV-Out AGP 8X for $99 (with tax it will be $113... :( )
Do you think it is worth it? Will it give me a nice boost, compared to what I have?
or do you have any other suggestions?
Guardian Angel, Thanks for the recommendation
Do you think this card is much better than the x1300?
BTW, Can someone please explain to me the difference between the 9xxx series (9600, 9700, 9800...) and the x series (x800, x1300...) ?
I am really confused about these two card series, and I need a way to compare between the cards.
Thanks!
Thanks!
with big pleasure
the x1xxx seires technology is more adventing then the 9xxx series
all the types of video cards comes in 3 levels
low end cards
mid-end cards
high-end cards
more info you can fined here
http://www.ati.com/products/radeon9800/radeon9800pro/index.html
http://www.ati.com/products/RadeonX1300/index.html
http://www.ati.com/products/radeonx800/index.html
and for your Q is the radeon 9800P is more powerful then the X1300
Thanks Guardian Angel!
So I understand that the x1xxx series is better than the 9xxx BUT because the 9800Pro is one of the best in the 9xxx series AND the x1300 is one of the lowest in the x1xxx series, then in the end the 9800Pro is better than the x1300... OK! :)
One last question:
Since I have the 9600, is it worth the $90 (tax included...) to get the 9800Pro? Is it a large jump in performance?
THANKS!
One last question:
THANKS!
there will be an a very large jump in performance
if you will have any Q in the Future you allways can trust this site
by the way if there r other Q that may appear go to just Click my ICQ Icon
have fun :xyxthumbs:
That's Great!
Thanks!!
:yelclap:
Hey Guardian Angel!
Well, the bas news is that the store was out of stock with the 9800Pro (the website wasn't updated). Also, the guy at the store told me that, compared with what I have (the 9600Pro), the 9800 will not give me a good boost in performance, and that it's not worth the $90. Is that true?
Also, he suggested I try to OC my card! What do you think, is it a good idea?
I downloaded ATITool and RedLine, and I'm not sure how to use them safely.
Do you have any suggestion (maybe another OC utiilty) on how to OC my card in a safe way? Are there any guides online how to use these utilities?
THANKS!
:s05:
k so you got two options first is OC that you can gain extra boost to graphic card but wont be נראה ממש לעין and לא תרגיש שממש ביצועים עלו
and you said 2 years you want to stay with card so i think this will be great..
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1779348&CatId=0
i know its more that you can afford but actually this card for AGP is the best (price/performance)
this card really שווה כל שקל
also this price are soooooo expensive i can give you that card in newegg $160
