עזרה בקשר לפאנל
שלום , אשמח אם מישהו יוכל להגיד לי מה אומר אם הפאנל של המסך סוני שלי הוא a-Si-TFT Active Matrix LCD Panel
קראתי בחיפוש על פאנלים , אבל אני לא ממש מבין בזה ורציתי לדעת איפה זה ממקם את הסוני הזה..תודה
There are 3 basic types of lcd panels. Tn, ips and mva/pva.
Tn type you should stay away from for photo editing. They are 6bit per color panels or 18bit overall. A true 24bit monitor will say 16.7 million colors in the specs. A tn based monitor spec sheet will say 16.2 million. And that is done with dithering. These tn panels boast the fastest response times and are wanted by hard core gamers.
ips type panels are used in most high end graphic pro monitors. True 24bit color (some even do 30bit) and the least color shift when looking from off angles. These have slower response times and are snubed by some reviewers because of this. Most review sites are for the gamer crowd.
mva/pva depending on who makes the panel are somewhere in between the other two. 24 bit color. color not as accurate as ips but better ones display blacks better. Good viewing angles and fairly good response times for the average gamers. They seem to be a good all around type of display.
