בעיה עם הקרנל
המערכת שלי היא דאפר.
יש לי בעיה עם הגרסה האחרונה של הקרנל (2.6.15-26-386) , כשאני בוחר בגראב את הגרסה הזו אני מקבל שגיאה בהמשך
faild start x server..... it's likly that it's not set correcly
זה קורה לי רק עם הגרסה הזו של הקרנל (בנתים אני עובד ב2.6.15-25-386)
הנה הפלט של הקובץ xorg.0.log:
X Window System Version 7.0.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 7.0
Build Operating System:Linux 2.6.15.7 i686
Current Operating System: Linux chch-desktop 2.6.15-26-386 #1 PREEMPT Thu Aug 3 02:52:00 UTC 2006 i686
Build Date: 16 March 2006
Before reporting problems, check [url]http://wiki.x.org[/url]
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Aug 23 14:28:34 2006
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Generic Monitor"
(**) | |-->Device "NVIDIA Corporation NV43 [GeForce 6600/GeForce 6600 GT]"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "stylus"
(**) |-->Input Device "cursor"
(**) |-->Input Device "eraser"
(WW) The directory "/usr/share/X11/fonts/cyrillic" does not exist.
Entry deleted from font path.
(**) FontPath set to "/usr/share/X11/fonts/misc,/usr/share/X11/fonts/100dpi/:unscaled,/usr/share/X11/fonts/75dpi/:unscaled,/usr/share/X11/fonts/Type1,/usr/share/X11/fonts/100dpi,/usr/share/X11/fonts/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
(==) RgbPath set to "/etc/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.8
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 10de,00e1 card 0000,0000 rev a1 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 10de,00e0 card 1458,0c11 rev a2 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,00e4 card 1458,0c11 rev a1 class 0c,05,00 hdr 80
(II) PCI: 00:02:0: chip 10de,00e7 card 1458,5004 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,00e7 card 1458,5004 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:2: chip 10de,00e8 card 1458,5004 rev a2 class 0c,03,20 hdr 80
(II) PCI: 00:05:0: chip 10de,00df card 1458,e000 rev a2 class 06,80,00 hdr 00
(II) PCI: 00:06:0: chip 10de,00ea card 1458,a002 rev a1 class 04,01,00 hdr 00
(II) PCI: 00:08:0: chip 10de,00e5 card 1458,5002 rev a2 class 01,01,8a hdr 00
(II) PCI: 00:0a:0: chip 10de,00e3 card 1458,b002 rev a2 class 01,01,85 hdr 00
(II) PCI: 00:0b:0: chip 10de,00e2 card 0000,0000 rev a2 class 06,04,00 hdr 01
(II) PCI: 00:0e:0: chip 10de,00ed card 0000,0000 rev a2 class 06,04,00 hdr 01
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 10de,00f1 card 1682,2119 rev a2 class 03,00,00 hdr 00
(II) PCI: 02:0b:0: chip 11ab,4320 card 1458,e000 rev 13 class 02,00,00 hdr 00
(II) PCI: 02:0d:0: chip 1095,3512 card 1095,6512 rev 01 class 01,04,00 hdr 00
(II) PCI: 02:0e:0: chip 104c,8025 card 1458,1000 rev 01 class 0c,00,10 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:11:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf8000000 - 0xfaffffff (0x3000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:14:0), (0,2,2), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[1] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]
[2] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[3] -1 0 0x00009c00 - 0x00009cff (0x100) IX[B]
[4] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[5] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[6] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[7] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfb000000 - 0xfcffffff (0x2000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0x50000000 - 0x500fffff (0x100000) MX[B]
(--) PCI:*(1:0:0) nVidia Corporation NV43 [GeForce 6600/GeForce 6600 GT] rev 162, Mem @ 0xf8000000/24, 0xe0000000/28, 0xf9000000/24
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xf0000000 from 0xf7ffffff to 0xefffffff
(II) Active PCI resource ranges:
[0] -1 0 0xfc004000 - 0xfc007fff (0x4000) MX[B]
[1] -1 0 0xfc008000 - 0xfc0087ff (0x800) MX[B]
[2] -1 0 0xfc009000 - 0xfc0091ff (0x200) MX[B]
[3] -1 0 0xfc000000 - 0xfc003fff (0x4000) MX[B]
[4] -1 0 0xfd001000 - 0xfd001fff (0x1000) MX[B]
[5] -1 0 0xfd000000 - 0xfd000fff (0x1000) MX[B]
[6] -1 0 0xfd005000 - 0xfd0050ff (0x100) MX[B]
[7] -1 0 0xfd004000 - 0xfd004fff (0x1000) MX[B]
[8] -1 0 0xfd003000 - 0xfd003fff (0x1000) MX[B]
[9] -1 0 0xf0000000 - 0xefffffff (0x0) MX[B]O
[10] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MX[B](B)
[11] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[12] -1 0 0xf8000000 - 0xf8ffffff (0x1000000) MX[B](B)
[13] -1 0 0x0000a400 - 0x0000a40f (0x10) IX[B]
[14] -1 0 0x0000a000 - 0x0000a003 (0x4) IX[B]
[15] -1 0 0x00009c00 - 0x00009c07 (0x8) IX[B]
[16] -1 0 0x00009800 - 0x00009803 (0x4) IX[B]
[17] -1 0 0x00009400 - 0x00009407 (0x8) IX[B]
[18] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[19] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[20] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[21] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[22] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[23] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[24] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[25] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[26] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[27] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[28] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[29] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[30] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[31] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfc004000 - 0xfc007fff (0x4000) MX[B]
[5] -1 0 0xfc008000 - 0xfc0087ff (0x800) MX[B]
[6] -1 0 0xfc009000 - 0xfc0091ff (0x200) MX[B]
[7] -1 0 0xfc000000 - 0xfc003fff (0x4000) MX[B]
[8] -1 0 0xfd001000 - 0xfd001fff (0x1000) MX[B]
[9] -1 0 0xfd000000 - 0xfd000fff (0x1000) MX[B]
[10] -1 0 0xfd005000 - 0xfd0050ff (0x100) MX[B]
[11] -1 0 0xfd004000 - 0xfd004fff (0x1000) MX[B]
[12] -1 0 0xfd003000 - 0xfd003fff (0x1000) MX[B]
[13] -1 0 0xf0000000 - 0xefffffff (0x0) MX[B]O
[14] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MX[B](B)
[15] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[16] -1 0 0xf8000000 - 0xf8ffffff (0x1000000) MX[B](B)
[17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[19] -1 0 0x0000a400 - 0x0000a40f (0x10) IX[B]
[20] -1 0 0x0000a000 - 0x0000a003 (0x4) IX[B]
[21] -1 0 0x00009c00 - 0x00009c07 (0x8) IX[B]
[22] -1 0 0x00009800 - 0x00009803 (0x4) IX[B]
[23] -1 0 0x00009400 - 0x00009407 (0x8) IX[B]
[24] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[25] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[26] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[27] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[28] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[29] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[30] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[31] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[32] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[33] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[34] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[35] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[36] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[37] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
ABI class: X.Org Server Extension, version 0.2
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.0.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.8762
ABI class: X.Org Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "type1"
(II) Loading /usr/lib/xorg/modules/fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.1.0
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.5
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.3
(II) LoadModule: "wacom"
(II) Loading /usr/lib/xorg/modules/input/wacom_drv.so
(II) Module wacom: vendor="X.Org Foundation"
compiled for 4.3.99.902, module version = 1.0.0
(II) Wacom driver level: 47-0.7.2 $
(II) NVIDIA X Driver 1.0-8762 Mon May 15 13:09:21 PDT 2006
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/lib/xorg/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 0.1.0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[22] -1 0 0x0000a400 - 0x0000a40f (0x10) IX[B]
[23] -1 0 0x0000a000 - 0x0000a003 (0x4) IX[B]
[24] -1 0 0x00009c00 - 0x00009c07 (0x8) IX[B]
[25] -1 0 0x00009800 - 0x00009803 (0x4) IX[B]
[26] -1 0 0x00009400 - 0x00009407 (0x8) IX[B]
[27] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[28] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[29] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[30] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[31] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[32] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[33] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[34] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[35] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[36] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[37] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[38] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[39] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[40] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[41] 0 0 0xfa0003b0 - 0xfa0003bb (0xc) IS[B]
[42] 0 0 0xfa0003c0 - 0xfa0003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Enabling RENDER acceleration
(EE) NVIDIA(0): Failed to load the NVIDIA kernel module!
(EE) NVIDIA(0): *** Aborting ***
(II) UnloadModule: "nvidia"
(II) UnloadModule: "ramdac"
(II) UnloadModule: "fb"
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
ד"א
אני משתמש בדרבירים של nvidia
יש לכם מושג איך לפתור את הבעיה?
אתה צריך להתקין שוב את הדריברים של NVIDIA
לא עזר
ד"א
לא יודע אם זה קשור אבל יש לי בעיה גם עם הדריבר "nv" - כשאני מפעיל את המערכת דרכו(משנה בקובץ xorg מ "nvidia" ל "nv")
לא משנה באיזה קרנל אני בוחר אני רואה פסים פסים בצבעים שונים(ב gdm)
אין כזה דבר לא עוזר, הוא מתלונן על כך שהוא לא יכול למצוא את הדריבר של nvidia (כי התקנת קרנל חדש) לכן, צריך להתקין את הדריבר, אם התקנת אותו (ואתה בטוח שהתקנת אותו) תביא שוב את הפלט של xorg.0.log
בקשר ל nv נסה לשנות ל vesa
כן מחקתי את הדריבר והתקנתי שוב
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Aug 24 12:22:25 2006
Fatal server error:
no screens found
ובקשר ל vesa זה עובד אבל מה הבעיה של ה "nv" ?
ומה הבדל בין "nv" ל vesa"?
ודבר אחרון - מה הבדלים בין הקרנלים? אני לא ראיתי הבדל אחד
תנסה להתקין לפי המדריך בוויקי של אובונטו, לקח לי להסביר לחבר בידיוק דקה וזה עבד לו
הבדל בקרנלים - אתה אף פעם לא תראה, זה בעיקרון תיקוני באגים
כן, למדריך הזה
לשאלה השניה ifconfig down ethX
אחלה עכשיו זה עובד גם בקרנל החדש.(גם הדריבר "nv" עובד)
תודה nim :yelclap:
יש לי עוד בעיה באובנטו - כל פעם(כמעט) כשאני מעלה את אובנטו אני צריך לגשת ל system->adminisration->networking לבטל את הכרטיס רשת ולאפשר אותו - כדי לגשת לאינטרנט
הבעיה היא שהכרטיס לא מקבל כתובת ip
החיבור שלי הוא mpls ככה שאין מה להגדיר -רק לחבר את המודם לכרטיס רשת והוא אמור לקבל כתובת ip ואז אפשר לגלוש
אם הכתובת איפי לא משתנה אתה יכול לשים אותה שם ואז זה פשוט יזכור
אני ינסה את הדרך הזו ,אבל למה יש לי את הבעיה הזו?היתה תקופה שזה כן עבד
  • 5 שבועות מאוחר יותר...
The problem is that you should use the "nvidia" driver, if you want to use nVidia GLX drivers (ie: proper hardware accelration).
compile the nvidia drivers and change in xorg.conf from "nv" to "nvidia".
of course make sure that the screen settings are configured properly.
By the way, do not forget to recompile the nvidia drivers EACH TIME you recompile the kernel. The drivers are staticly linked to the kernel. You will also need to run "modules-update" afterwards too.
