צריך המלצה לסטיק זיכרון DDR2 1GB
זה מה שיש לי כרגע:
Device Description
DIMM1: Micron Tech. (256 MB DDR2-533 DDR2 SDRAM)
DIMM3: Micron Tech. (256 MB DDR2-533 DDR2 SDRAM)
Field Value
Memory Module Properties
Module Name Micron Tech.
Serial Number None
Module Size 256 MB (1 rank, 4 banks)
Module Type Unbuffered
Memory Type DDR2 SDRAM
Memory Speed DDR2-533 (266 MHz)
Module Width 64 bit
Module Voltage SSTL 1.8
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings
@ 266 MHz 4.0-4-4-12 (CL-RCD-RP-RAS)
@ 200 MHz 3.0-3-3-9 (CL-RCD-RP-RAS)
Memory Module Features
Early RAS# Precharge Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
Memory Module Manufacturer
Company Name Micron Technology, Inc.
Product Information http://www.micron.com/products/category.jsp?path=/DRAM
תודה לעוזרים
Twinmos DDR2 533
