אולי המיפרט הטכני של הWII
טוב המיפרט הטכני של הWII אולי נחשף
EXCLUSIVE: Wii Know A lot You Dont- Nintendo Wii Specs Fully Uncovered!!!
So far Nintendo have done a very credible job in keeping information regarding the Wii to a minimum. Well all that has just changed! An anonymous Wii developer has sent to us slurry of information regarding Nintendos next-gen console, all thats left now is a confirmed release date and price to complete the puzzle. Believe us when we say, this article is a MUST READ, you wont be disappointed. Prepare to get educated
Wii Know A Lot You Dont... but will Enjoy!
Anyway, we've done enough talking thus far, prepare your eyes for a textual feast on the joys to behold with the Wii.
The Wii Hardware
- Nintendo Wiis Broadway CPU operates at 729MHZ with a maximum bandwith of 1.9gbyte/sec.
- Nintendo Wiis HollyWood GPU is clocked at 243MHZ, the internal memory of it includes 3mb of embedded graphics memory and 24megabytes of high speed main memory.
- 64megabytes of GDDR3 (MEM2) as the external main memory. Just like the internal memory, it can be accessed from the CPU and GPU with a maximum bandwidth of 4gbytes/sec and can also store programs in the MEM2.
- The GPU of the Wii is identical to the GCs but it is on average 1.5X faster.
Wii's Optical Disc Drive
- Opitcal Disc Drive (ODD) supports single and dual layer Wii disks, discs eject with software or button and the maximum read speed is the equivalent of DVDx6.
- Two main disc types supported the single sided 12cm single sided 4.7gb and the double sided 8.51 GB. Nintendo GC discs also supported. Some of the capacity of the discs are used by the system and games can not use full disc space.
- Inserting a disc will start the Wii console, even if it was already in an off state. Pressing the eject button will change the console to an on state to take out the disc also.
General Overview
- An optional wired LAN adapter that connects to a USB port is in the pipeline for users who do not possess a wireless LAN set-up currently.
- Internal non-removable 512MB flash memory used to storage game save data and downloadable content thus eliminating the Need for a memory card.
- Both Wii discs and Gamecube discs can be played via an intelligent mode swap. When running in GC mode, the Wiis CPU and GPU will lower to the respective speeds of the GC and some of the MEM2 functions as ARAM.
- Software development environment is an upgrade to the Dolphin SDK used with the GC; the same libraries are used so developers can get up to scratch easily as well as the possibility of ports being easier.
- The following interfaces are included with the Wii; SD card slot, Wireless controller, two USB 2.0 ports, wireless LAN, 4x GC controller ports, 2x GC memory card slots and an AV multi output jack (only an analog jack).
- Supports Wii disks (one sided 12cm) and GC discs (one sided 8cm) and console auto switches depends on what disk is inserted
- More than just the Nunchaku is planned as an extension. GC peripherals such as DK bongos can be used in both Wii and GC modes.
- Three power status, on, off and unplugged. To prevent mistaken turn offs, the power button must be held for about a second.
The Wii Control System
- The Wii controller features; Direct Pointing Device, Three axis accelerometer, Wii power button (remotely turn console on/off), buttons, wireless connectivity, indicator LEDs, rumble, battery powered (two AA alkaline batteries) and ability to connect extension unit.
- The Wii controller supports three types of operations; by itself, with a nunchuk extension or with a classic controller. Classic controllers will ship to developers during August 2006.
- The SYNCHRO button on the Wii controller exchanges wireless ID numbers when pressed at the same time as SYNCRHO on the Wii console. Wireless communications are only possible with consoles which have been authenticated.
- The rumble motor can be turned on and off and the intensity can be changed.
- The Wii remote has a pointer for fine movements as well as a motion sensor +/- 3.4G suitable for larger body movements, the nunchuk attachment has a sensor of +/- 2G
- The sensor bar must be placed above or below a TV set, the pointer measures coordinates between the ends of the bar which are about 20cm apart.
- The Wii remote has four status, disconnected, communicating, establishing connection and pairing wait status.
- The pointer can measure co-ordinates within bounds of rectangle centered upon the sensor bar, thus it can also measure points beyond the screen. It also responds to strong light sources, windows, fluorescent lamps, fireplaces, mirrors etc.
- Due to players hands shaking while holding the controller, a ring buffer allows a precise direction to be created to hold and average accelerator samples.
http://www.maxconsole.net/?mode=news&newsid=8802
טוב אם זה נכון זה קצת מאכזב
מיצד אחד הWII משמעותית יותר חזק מהקוביה אבל רציתי יותר כח
והמדיה זה לא בדיוק DVD וזה מאכזב מבחינת...
למרות שאני מעריך שהכונן עצמו יהיה מסוגל לנגן גם DVD
אבל יש דברים טובים
הפיתוח מישחקים אמור להיות מאוד זול והקונסולה אמורה להיות זולה
גם התמיכה לאחור בקוביה אמורה להיות טובה
בקיצור יש היתרונות וחסרונות ואין לי מושג מה כל הנתונים אומרים על הגרפיקה במישחקים עצמם
למשל יש 3 סוגי זיכרון על הכרטיס הגרפי ואין לי מושג למה
ואני לא יודע כמה צינורות עיבוד יהיו וכו
אבל אני עדין רוצה ליקנות תWII ואם המישחקים יהיו מספיק זולים אז אפילו בלי ...
  • תגובות 98
  • צפיות 9.5k
נשמע כמו X-BOX משופר קמעה..אפילו זה לא..הכרטיס הגרפי זהה לזה שבקיוב..ז"א גרפיקה זוועתית..כמו שהייתה בתערוכת E3.. :s07:
וואו
ווי נשמע מסריח לחלוטין :hi:
חלש.......מאוד חלש, הדבר היחיד שנשאר בה נחמד זה השלט שלה ואוליי המחיר הזול.
מאכזב.. לפחות היא תהיה זולה לא כמו הPS3 והXBOX 360
נשמע שמישהו פה נחנק מהציפור שהוא בלע
כבר עדיף לקנות PC במקום
:s07::kopfpatsch:
ונעבור לדיון: ATI אמרו שהכרטיס הגראפי של WII יכול להציג הרבה יותר מהגראפיקה שבמשחקים שהוצגו.
הזמן יגיד לנו.. :nixweiss:
קונסול חלש הוא לא מה שהופך משחק לרע.
קודם כל הWII אמורה היתה להיות חלשה משמעותית מה360 או מהPS3
ככה שזה לא דבר חדש
חוץ מיזה המישחקים שהוצגו בE3 פותחו על ערכות פיתוח של הקוביה
וזה אומר שיכולים לשפר משמעותית תגרפיקה אחרי הדור הראשון של המישחקים
ועוד דבר זה אולי המיפרט אבל לא בטוח
חוץ מיזה לWII תיהיה שליטה חדשנית הוא יכלול דפדפן אופרה מובנה ויהיה לו כרטיס זיכרון פנימי לשמירות והורדות קטנות
כל זה במחיר יחסית מאוד זול
נכון שיש חסרונות בזה אבל יש גם יתרונות ומי שרוצה קונסולה דור הבא בגרפיקה שיקנה 360 או PS3 וישלם הרבה בישביל זה
אני עדין מעדיף תWII
ההבדל המשמעותי בין הקיוב לwii הוא השלט והתמיכה באינטרנט..ואולי עוד כמה מגה הרצים...
150 דולר על השלט והרשת...זה קצת הרבה לפי דעתי...
לקוביה יש 40 מגה זיכרון בכל הקונסולה
לXBOX הראשון יש 64 וזיכרון יותר איטי משמעותית מהWII
DRAM מול GDDR3
ככה שזה לא רק כמה מגה הרצים וכמו שאמרתי יש יתרונות וחסרונות בדרך הזות
המחירים צפוים להיות זולים מאוד יחסית לשוק יהיה יותר מקוריות ויקח פחות זמן משמעותית לפתח מישחקים לWII
לאומת זות הגרפיקה תיהיה הרבה פחות טובה מהמיתחרים ואפשר לישכוח מHD אמיתי
אני אישית מעדיף תWII וזה בין 200 ל250 דולאר דרך אגב
וכל אחד יכול להחליט מה עדיף בשבילו
תPS3 אם הבלו רי ובו ניתעלם מהבעיות בטח יהיה מאוד קשה ליפרוץ והמישחקים יהיו מאוד יקרים וגם הקונסולה
ה360 ניכשלת ביפן מצליחה בארצות הברית וככה ככה באירופה
והיא מתאימה בעיקר למי שאוהב מולטיפליר וHD
הWII פונה למיגוון רחב של קהל וגם לגימרים שיקנו PS3 או 360 ביגלל המחיר שלה ונישאר לחכות וליראות מה יקרה אחרי ההשקה
כל הרכיבים של הwii כמה שהם יחדשו (יותר נכון כמה שהוא יחדש) עדיין לא הופכים את הקונסולה לדור הבא...
250 (פחות או יותר) זה הרבה בשביל גיימקיוב משופר אם אפשר לקרא לו ככה
בלי לפגוע אבל אם ה WII היה עולה 300 דולר לא היית קונה? היית כי אתה פנבוי של NINTENDO
בקשר למפרט אם המחיר יהייה מתחת ל 250 או 250 אז זה בסדר אבל אם זה יהייה יותר זה נקרא להיות פראייר אבל פנבוייז של NINTENDO קונים.
בכל אופן גם ל 360 צפוי להיות בקר מתקדם כמו הווי והוא כרגע בפיתוח.
עדיין איזה משחקים מעניינים יש ל WII להציע למישהו שהוא בן 16 ומעלה או 15 ומעלה?
SUPERMARIO שאני מת עליו כבר לא בשבילי.
אולי בשבילך.
אל תבין אותי לא נכון אני אוהב לשחק במשחקים כאלה אבל לא יותר מדי.
בכל אופן לסיכום: תעשה מה שבראש שלך
הWII יותר חזקה מהXBOX הראשון ובXBOX הצליחו לשים את HL2 ואת דום 3
אומנם לא באיכות של PC נורמלי אבל הצליחו
חוץ מיזה ביגלל ערכות פיתוח ותוכנות דומות לקוביה מפתחים יוכלו לנצל תWII מהר מאוד
ויש גם תאימות לאחור מאוד גדולה שמה שמענין אותי באמת זה תאימות לקוביה שלא שיחקתי במישחקים שלה
וחוץ מיזה היום אמרו לי תמחיר של הG6 +פסכרד 3+DS LITE וזה הרבה הרבה יותר מהמחירים בחול
(ציפיתי למחיר גבוה אבל לא כזה)
ככה שאני לא יקנה LITE אלה אם מישהו יטוס לארץ נורמלית אז אני מת לקונסולה של נינטנדו
אולי בשבילך.
1-אני בטח לא יקנה בכל מחיר ובהתחלה חשבתי ליקנות 360 או PS3
2-הWII צריך לעלות עד 250 -אין מחיר סופי
3-הבקר של הWII בא אם כל קונסולה ככה שמפתחים חיבים לפתח בשבילו בניגוד לבקר של ה360 או למצלמה החדשה שסוני מפתחת
4-מטרויד\זלדה\RPGים של סקוור איניקס\ ואני בן 28 אז מה
