בעייה בהתקנת דרייבר לכרטיס מסך של nvidia (ובעיות נוספות בהמשך)
לא הבנתי , אני רוצה רזולוציה 864*1152 על 100HZ , איך אני עושה זאת?
אני רוצה להוסיף את Windows XP למסך בחירה של הBOOT , הווינדוס נמצא על כונן SATA והלינוקס נמצא על כונן IDE , מה אני אמור להוסיף?
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not change this entry to 'saved' or your
# array will desync and will not let you boot your system.
default 0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 3
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=/dev/hdc1 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd0,0)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## ## End Default Options ##
title Ubuntu, kernel 2.6.15-26-386
root (hd0,0)
kernel /boot/vmlinuz-2.6.15-26-386 root=/dev/hdc1 ro quiet splash
initrd /boot/initrd.img-2.6.15-26-386
savedefault
boot
title Ubuntu, kernel 2.6.15-26-386 (recovery mode)
root (hd0,0)
kernel /boot/vmlinuz-2.6.15-26-386 root=/dev/hdc1 ro single
boot
title Ubuntu, kernel 2.6.15-23-386
root (hd0,0)
kernel /boot/vmlinuz-2.6.15-23-386 root=/dev/hdc1 ro quiet splash
initrd /boot/initrd.img-2.6.15-23-386
savedefault
boot
title Ubuntu, kernel 2.6.15-23-386 (recovery mode)
root (hd0,0)
kernel /boot/vmlinuz-2.6.15-23-386 root=/dev/hdc1 ro single
boot
title Ubuntu, memtest86+
root (hd0,0)
kernel /boot/memtest86+.bin
boot
### END DEBIAN AUTOMAGIC KERNELS LIST
תודה.
  • תגובות 30
  • צפיות 3.3k
CTRL+C CTRL+V
תיבדוק בהגרות של הKDE/GNOME
בהגרות של ה
grub
הגדרתה 3 פעמים את הלינוקס ולא הגדרתה את הווינדוס
זה צריך להיות משהוא בסיגנון של:
root (hd1,0)
makeactive
אתה צריך רק ליבדוק על איזה מספר של
hd
ואיזה מספר מחיצה הווינדוס נימצה, אתה יכול לעשות:
su -
grub
root(hd
ואז לילחוץ טאב וזה יראה לך איזה הרדיסק באיזה מספר
למשל ההרדיסק של הווינדוס יושב על 1 אז תוכל לעשות
root(hd1,
ושוב לילחוץ טאב וזה יציג לך את המחיצות בדיסק, כך תוכל לדעת איזה מספרים להגדיר בקונפיג
אני לא הגדרתי.
su לא עובד לי טוב , כשאני רושם את הססמא הוא אומר שהיא לא נכונה , ניסיתי sudo במקום.
רשמתי grub ואז ENTER , נכנס לי למצב של <grub , כשאני רושם root(hd או root(hd1, ועושה את הקטע שאמרת עם הטאבים אז זה לא עושה כלום חוץ מלהעתיק את אותה שורה שוב מחדש בשורה הבאה.
insan1ty, מאיפה הקוד הזה שרשמת? איך אני מגיע אליו?
אשמח לעוד עזרה
/etc/X11/xorg.conf
אתה נכנס לאתר שהבאתי, ומזין את הנתונים, לגודמא אם הרזולוציה היא 1152x864@100 אז הוא יביא לך את הפלט הבא:
# 1152x864 @ 100.00 Hz (GTF) hsync: 91.50 kHz; pclk: 143.47 MHz
Modeline "1152x864_100.00" 143.47 1152 1232 1360 1568 864 865 868 915 -HSync +Vsync
את זה אתה דוחף תחת
Section "Monitor"
ב
/etc/X11/xorg.conf
ואז באותו הקובץ תחת
SubSection "Display"
אתה כותב ב-Modes את ה"שם" של הרזולוציה:
Modes 1152x864_100.00 bla bla bla
ז"א, מצטער על התגובה המאוחרת :\
הקובץ שלי שונה ואני היסתבכתי
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/X11/fonts/misc"
FontPath "/usr/share/X11/fonts/cyrillic"
FontPath "/usr/share/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/X11/fonts/Type1"
FontPath "/usr/share/X11/fonts/100dpi"
FontPath "/usr/share/X11/fonts/75dpi"
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us,il"
Option "XkbOptions" "grp:alt_shift_toggle"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ExplorerPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/wacom" # Change to
# /dev/input/event
# for USB
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
# /dev/input/event
# for USB
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
# /dev/input/event
# for USB
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "NVIDIA Corporation NV44 [GeForce 6200 TurboCache]"
Driver "nv"
BusID "PCI:5:0:0"
EndSection
Section "Monitor"
Identifier "E92f+"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "NVIDIA Corporation NV44 [GeForce 6200 TurboCache]"
Monitor "E92f+"
DefaultDepth 24
Depth 1
Modes "1920x1440" "1856x1392" "1792x1344" "1600x1200" "1280x1024" "1280x960" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
אם תוכל לערוך לי אותו אשמח.
Section "Monitor"
Identifier "E92f+"
Option "DPMS"
EndSection
Section "Screen"
Monitor "E92f+"
DefaultDepth 24
Depth 1
Modes "1152x864_100.00" "1920x1440" "1856x1392" "1792x1344" "1600x1200" "1280x1024" "1280x960" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
תודה רבה!עובד!!!
עוד שאלה:
לפעמים כשאני מפעיל תוכנית ויוצא ממנה השימוש בCPU נשאר על 100% ואז כל הפעולות במערכת הפעלה נהיות מאוד איטיות , איפה יש את מנהל המשימות כדיי שאני אוכל לסגור משימה שמשתמשת בCPU ללא צורך או להקל על הRAM בשימוש הזכרון גם כן ע"י פינוי תוכניות ברקע.
sudo killall nameofprocess
למה לעזלל SUDO? :nono::bash::kopfpatsch:
למה להשתמש בטרמינל ולא במנהל משימות של האובונטו?:x
simla101, כי זה הרבה יותר מהיר?
nim901, אני מבקש ממך להקטין את החתימה ;D
זה בגודל מצויין
אני צריך לתת לך לינק לחוקי הפורום?
אם אתה מרגיש צורך
בלופ ;D
http://hwzone.co.il/community/index.php?topic=59714.0
חתימה ויזואלית (תמונה) מוגבלת לגודל של 300x100 פיקסלים, ולמשקל של 30KB לכל היותר.
בערף ;D
