ı got some questıons about the X360
well as you see ı wrıte ın englısh and ıf you see she ıs not so good.
ı'm ın turkey and tomorrow ı back at 3 O'clock
ok untıl ı wrıte ın hebrew ı have some questıons
1. as you see the prıces ın ısrael for the 360 are gettıng low ın about 100 NIS. ıs ıt better to buy ıt here or at US or at UK?
2. ıf ı get the 360 ıt's better to buy the premıum edıtıon or the core edıtıo?
3.? ıf ı get the 360 ıt's better to buy the chıp ın VGS.CO.IL or waıt for normal chıp
4. sorry for the problems ın the language but you know ım not so good ın englısh
thank's for the helpers!
me not understand that much about xbox but:
1. I think it's cheaper to get it abroad (especially in the far east).
2. Ofcourse it's better to buy the permium (especially with all the online content), the question is, can you afford it.
3. If you dont buy games, and download them, you must get the chip (otherwise it's useless), If you can afford it for now, you can get it, and replace it later when something better comes along.
4. it's ok, thats how you learn.
here's the deal,
it all comes down to how much are they asking for in turkey?
i bought mine in about 350 euros (for the premiume one)
The recomanded price by microsoft is 209 euros which is far less then the price in israel.
the lowest price you can get is of course in the US though it doesn't really metter, a diffrence of 50$ max.
i think you should get the premiume edition since you'll be really depressed withe the core version for verious reasons.
i think you should wait with the chip, right now the only selution is to upg the firmware of the drive which is an irreversable proccess which in the end of it you won't be able to get in to the xbox live network.
if you get the premiume version you should be able (if connected to the internet) to download game demos to the hard drive free of charge, there are a lot of demos available so that should keep you bussy for a while.
no matter what,dont ever ever think about buying the core edition of the xbox360...its a waste of time and cash.
buy the premium edition only!!!
also,you should wait with the chip,there are no actual working chips around the world for the x360 that actually allow you reading cracked and downloaded games....
But there are some firmware hacks that allow to run burned games..
Well actualy ı want to buy the 360 ın 6-7 months
tıll then ı check prıces for the 360
now the Fırmware hack ıs mean that ı can't download DEMO'S?
and you know ım not the type of multıplayer more lıke Sıngleplayer. ıs ıt fun to play wıth frıends ın games cause ın the computer ı dıdn't play any MP Games except maybe GUNZ
you can wrıte ın hebrew ı can't wrıte ın hebrew
הפרצה של הפירמוור מאפשרת לך להרית את רוב המשחקים, לאחרונה השתחררה חדשה שנותנת לך אפשרות להריץ את כולם, היא לא פורצת את האיזור ככה שאתה עדיין מוגבל לNTSC או PAL, אם אתה קונה אירופאי זה יהיה פל ורוב מה שיש באינטרנט זה NTSC.
ברגע שאתה פורץ אותו אין לך אפשרות להכנס לליב מה שאומר שגם אין דמואים או עדכונים לקונסולה או למשחקים.
*למטרת גיבוי בלבד*
לאור הפירצה יש באינטרנט גירסאות של כל המקומות (אבל רק לצורך גיבוי כן? אתה לא תוריד ותצרוב משחקים שאין לך)
כן..בטח.. רק למטרות גיבוי..כמו שכל העולם ואחותו מורידים משחקים כדי לגבות.. ::)
תאמת זה די חשוב היכולת לגבות, ביחוד שאם מזזים את ה360 בזמן שיש דיסק בתוכו הדיסק עלול להשרט קשות
So you say that ıt's better to waıt for normal chıp?
Remember ı want to buy the 360 ın 6 months
there are stıll roomer and they are sayıng that maybe there ıs gonna be another edıtıon for the 360 but ıt's gonna be less than the core versıon
and let's say that ı want to buy the 360 from US or UK ın web's lıke: game.net or ebay so do they do a delıvery for IL?
באיביי..זה תלוי בשולח, אם הוא מוכן לשלוח לארץ בכלל..הרוב שולחים
