יצאו גירסאות דרייבים חדשים ל כריטסי הקול של הרקולס DIGIFIRE, Fortissimo, GTXP
הנה השיפורים :
DESCRIPTION :
Improvements:
Unified driver structure (Game Theater XP/ Gamesurround Fortissimo III 7.1/ Digifire 7.1)
This allows for a better engineering response time to any known bugs.
Simplified End-user installation process:
Cleaner install / uninstall involving less registry manipulation.
Improved performance & stability (notably with Win XP)
Memory management, stream-lined registry handling
DSP resource usage improved
8 channel WAVEFORMATEXTENSIBLE implemented. Compatible with Power DVD PRO EX in 6.1 and 7.1 DD EX modes.(if available in your hardware)
8 channel analog output using the headphone jack. (if available in your hardware)
MiniDisc® mode added. Help to resolve the tracking problems & improves compatibility with MiniDiscs® recorders.
Fixes:
Various mixer bugs addressed.
Disappearing center & sub
Better handling of gameport resources with Nvidia nForce chipset equipped motherboard.
Note:
The Help files are available separately in the Application/utility section.
INSTALLATION :
Download the appropriate driver package.
If you are running WINDOWS XP, make sure your network cable is physically disconnected from the computer and remains so until drivers are fully installed (this is to prevent Windows Update from simultaneously upgrading your drivers)
Uninstall previous drivers.
Launch the installation package (Files will be copied to C:/Program files/hercules/audio/Game theater XP 7.1)
Follow the instructions.
להורדת הדרייבים לחצו פה
אני חושב שכבר דיברנו עליהם כאן
