אפשר ליצור אלבומים ב-sansa!!! רק שזה מאוד מסובך!
מצאתי ביקורת שכוללת מדריך ליצירת תיקיות בסנסה
רק שזה מאוד מסובך ואני בכל מקרה עדיין לא הצלחתי...
אם מישהו יצליח ליצור תיקיות בעזרת המדריך הזה אשמח אם הוא יתרגם אותו לעברית
(בגלל שהמדריך באנגלית ומתאר את השימוש ב- WMP 10 בגירסא האנגלית
קשה לעקוב אחריו בעזרת הגירסא העברית)
הנה זה, מקווה שתצליחו לעקוב:
First the player. - The buttons are easy to use and intuitive. The menu system is also easy to use and intuitive and the large screen makes it easy to navigate. Unfortunately the belt clip costs extra, but is worth it for the convenience of portability without an annoying armband. The battery life is great, also.
The only flaw I've found in this player is that it's not a flash drive that can be easily carried around and attached to any computer to transfer files.
Now for the software. You are required to use Windows Media Player 10 (WMP) if you want to organize your files. This software is designed to bring intelligent, technology oriented people to their knees begging for mercy. If you require no organization of your files, don't even bother with the software, simply drag and drop your music into the "Music" folder in the SanDisk directory.
I however like to have separate files of music on the player -- for example, one for music files and one for audio book files. If you create separate folders for these files in the directory, you will not find them separated on the player. Instead, you must create "playlists" using WMP and "sync" them to your player. If you live long enough to see that accomplished, all you have to do with your player is press the Menu button, select Play Music, scroll to Playlists and select it, and there are your folders!
Here's how to not waste hours of your valuable lifetime figuring out how to make WMP do this for you: do the following in this order. BEFORE doing anything else with the software, Select the Library tab. Go to File at the top of the window (if it's not there, right click at the top of the window and select Show Menu Bar), select Add to Library and By Searching Computer. Select the folder containing your music files and search. This will take a long time and will end with no apparent result.
Click close and go to the menu in the left frame of the window. Click All Music. WMP will have sorted your music into all sorts of possibly useful combinations. If you want to see the list of ALL your songs, go to rated songs and select unrated -- since they all start unrated. Now all your songs will open in the Library frame (center frame) and you can sort them by clicking the columns. You can choose the colums by clicking Library Options, Chose Columns. Be careful what you do with songs in the Library -- deleting them here can delete them from your hard drive!
Now you can create a playlist. Go to the right side of the window, to the blue strip that looks like a border but is actually a separate frame. Click the menu at top, choose New List, then Playlist. Drag songs from the Library frame to the Playlist frame. Save frequently using the menu above the right frame (it changes names, so don't get thrown off by that).
Once you've created your playlist, it will show up in the left frame of the window under My Playlists. If you open a playlist here, it opens in the Library frame. Any changes you make in the Library are permanent, regardless of whether you save or not.
Now plug in your player, and click the Sync tab. Click Setup Sync and select the folders (ie, playlists) you want to put on your player. Use the drop down menu to add only the playlists you have selected (there are a bunch of default playlists the WMP makes up, in addition to the useful ones you have made.) Select OK and start the Sync.
At this point WMP freezes on me and I have to end the unresponsive program using Task Manager. I then reopen the program and resume the Sync, usually successfully. The Sync takes a long time. If you change your playlists and you want to "sync" those changes to your player, you do that via this method. You must resync ALL playlists you want to stay on your player, even those you have not changed, or they will be removed from you player.
Good luck. I hope these instructions (strangely not included with the player or WMP) will help you love your fabulous player and not hate it because it's software is so not user friendly!
על איזה דגם הם מדברים?
זה תופס לגבי כל סדרת ה- m200
לגבי שאר הדגמים אני לא יודע...
