כבל רשת מוצלב
שלום לכולם
אם מישהו יודע אילו חוטים יש להצליב כדי להפוך כבל רגיל למוצלב שיגיב בבקשה.
תודה.
On one end use the standard color order: White/Orange-Orange,White/Green-Blue,White/Blue-Green,White/Brown-Brown .
Clue: It doesn't really matter what you do with the brown and blue pairs since only the orange and green pairs are used for standard network data transmission.
For the other end, switch the location of the orange and green pairs (so you switch white-orange with the white-green, and switch the solid orange with the solid green giving you the color order: White/Green-Green,White/Orange-Blue,White/Blue-Orange,White/Brown-Brown).
