איזה ביטורנט אתם משתמשים ?
איזה ביטורנט אתם משתמשים ? ולמה 1,337 הצבעות
  1. 1. איזה ביטורנט אתם משתמשים ? ולמה
כנס לפורו שלהם
http://forum.utorrent.com/viewforum.php?id=3
1.4 I get "Error: Access Denied" / "Error:the process cannot access the file because it is being used by another process" and µTorrent halts the torrent! (Google/MSN Desktop, possibly some anti-virus software, Explorer's thumbnail view, may not be any of the above)
Error: Access Denied can be caused by numerous things. The most common cause seems to be Google and MSN Desktop. A possible fix is turn off the indexing feature, or to uninstall them. Excluding the folders from indexing does not work.
Another fix is to turn off diskio.flush_files, but you will lose the benefit of flush files (diskio.flush_files makes µTorrent close file handles every minute. This helps reduce the effect of Windows managing the system cache badly). Since flush files closes the handle every minute, Google/MSN Desktop try to open the file every minute, and this prevents µTorrent from writing.
The best solution is to simply uninstall Google/MSN Desktop, though.
One of the simplest causes of this is that you inadvertently have two copies of µTorrent running and using the same torrents. Open the Task Manager (CTRL SHIFT ESC or right click on the system clock -> Task Manager), and see if there's more than one utorrent.exe in the Processes tab. If this is the case, close both of them and start up µTorrent again.
It is possible that an anti-virus' real-time scanner may cause this, but there is no known AV that causes this error. If it does, the same fixes for Google/MSN Desktop apply (exclude the folder(s), uninstall the AV/disable the real-time scanner, or turn off flush files).
A third possibility is that you are viewing the folder while it's downloading, and Explorer is set to thumbnail mode. If this is the case, Explorer would try to access these files while viewing the folder in Thumbnail mode, and lock out µTorrent from writing. The solution is to not view the folder until the download is finished, don't use Thumbnail mode, or turn off flush files.
It's also possible that Explorer is trying to read the media files (mp3, avi and so on) in the folder to make thumbnails, show you information about them, or preview them. You can unregister the media indexer (Start -> Run -> regsvr32 /u shmedia.dll ), and/or unregister the image indexer (Start -> Run -> regsvr32 /u shimgvw.dll ) as an alternative for either case, not view the folder, or turn off flush files.
A FOURTH possibility is that you set the files to read-only, which would prevent µTorrent from writing. This only affects downloading; µTorrent can seed files that are set to read-only. However, if the error appears when trying to seed, it may mean that the original files are damaged and are failing the hash check.
  • תגובות 31
  • צפיות 2.3k
אוקי קודם כל תודה רבה על הציטוט
לא ממש הבנתי למה מתכוונים בשני האופמיות הראשונות
אבל נראה לי שזה האפשרות השלישית
שיניתי את הטאמבנייל בתקיה הזאת וגם לא פתחתי אותה
אבל עדיין הוא נותן לי את השגיאה הזאת!
אתה יכול להסביר לי מה בדיוק הם התכוונו בראשון ובשני?
תודה רבה
