X1900XT reviews
Previos tread got closed before i can respond,so here it goes
All ATI vs. Nvidia thing got way off the proportion on this forum
And funnny thing are ,that this was done by ppl,who dont know anything about GPU's
I used to have numerus ATI's&Nvidia product over passt 8 years,infact i got it know to, so i can speack from hardware user point off view and not from"forums reader"who catch peaces off info from alot web sorces
I aint thought im gonna say this one day but,x19xx GPU family just destroys Nvidia
In all game benches with high filters they got from 15% to 90%^ over current"hardtofind" 7800gtx 512mb
And this is resolution that ppl who buys highend cards playing
Doesnt matter if it single or xfire setup-x19xx is to good for competitors
Even 9700 series doesnt beat they competitor so hard as x19xx did
And what is important ATI did it with "new" approch 16ROPs+1-3-1 ALUs scemme
And its realy doesnt matter if Nvidia can top it in march,cause by then we gonna see another refrash by ATI, i can surely say that ATI now in lead in highend GPU market
I hope this post doesnt sound funboyish,cause for buyers sake i hope Nvidia can came up with something good instead off another refrash
Regards
לא בדקתה מספיק סקירות:
http://www.tomshardware.com/2006/01/24/ati_radeon_x1900_heats_up_with_48_pixel_pipelines/index.html
http://www.anandtech.com/video/showdoc.aspx?i=2679
http://www.guru3d.com/article/Videocards/315/
חחח 90% בטח ::)
תבדוק את הבמבחנים שוב....
מה הקטע המוביל של השוק אתמול היו NV היום ATI מחר NV וכו....
You better read from links you put see pic below
In F.E.A.R with softshadows on its over 90%
In COD2 its over 80%
And this is on 1600x1200,put it on higher res. or Xfire and get even bigger lead
[attachment deleted by admin]
This is from anand link you want me to read
/i\
מה הקטע לתת את המשחק שהוא הכי גרוע בו?
קבל תוצאות:
*במבחנים משווים בין X19XT ל78GTX512 כי X19XTX זאת סך הכל גרסת OC של X19XT ואין במבחנים את גרסת הOC של 78GTX512
קבל תוצאות:
מדהים,הבאת מבחנים של משחקים אשר יש לNVIDIA יתרון!
תביא F.E.A.R ,HL2 ונדבר..
מה הקשר ?
לדוגמה FAR CRY בנוי במיוחד לATI...וגם HL2....
בכל מקרה בבקשה:
מה הקשר ?
בכל מקרה בבקשה:
סתכל על הבאנץ ה 2
איך ה 1800XT עובר את 19XTX אם ה 19XTX יותר חזק ממנו.. :s07:
בקיצור, 95% מההשוואות נותנות לX1900XT\XTX את הכתר.
ואגב אהבתי תהפרש הענקי בCOD2 :smile1:
מה בקיצור?
רק בCOD2 וFEAR ...זה 95%? :kopfpatsch:
וכמו שאמרתי צריך להשוות את X19XT ל78GTX512 ....
מה בקיצור?
מה זה משנה ה XTX וXT עדיין יותר משתלמים מ78GTX512 בתשלום וגם בביצועים
ועוד מעט יהיה ירידה גם ב1800XT 8)
שאמרתי 95% התכוונתי לזה ש95% מהביקורות ברשת נותנים לו ציון גבוה יותר.
וזה לא משנה גם הXT חזק יותר מהGTX512.
ומה הקטע שלך עם לא להשוות אותו לXTX?
כמו שאשני זוכר גם GTX512 זה GTX256 מומהר עם עוד זיכרון.
נכון במחיר הX19XT הכי משתלם אין לי בעיה בזה וX19XTX ממש אבל ממש לא משתלם איזה100 דולר יותר רק על OC קטן...=לא שווה!!! :-\
ואם הייתה לי ברירה בין X19XT ל78GTX512(במחיר)אז כמובן הייתי לוקח את X19XT בכללי אין כימט הבדל ב30-40FPS+ :nixweiss:
הכי כדי לקנות 78GT ולחכות איתו עד DX10 הוא יספיק עד אז.. ::)
^^^ לא בין GTX512 לGTX256 יש הרבה יותר הבדלים...
הקטע לא להשוות אותם זה כי זה סך הכל גרסת OC לX19XT שנתנו לו שם חדש אם כבר אז להשוות 78GTX512OC וX19XTX אז זה יהיה הוגן ב100ֵ...
הקטע לא להשוות אותם זה כי זה סך הכל גרסת OC לX19XT שנתנו לו שם חדש אם כבר אז להשוות 78GTX512OC וX19XTX אז זה יהיה הוגן ב100?...
כרטיסים עם תמיכה מלאה ב DX10 ומשחקים שיצאו עם תמיכה מלאה ב DX10 לא לפני 2007! :smile1:
