בעיה בהתחברות לאינטרנט במנדריבה 2005
לאחר שהתקנתי את אשף האינטרנט הישראלי , ניסיתי להתחבר לאינטרנט אך עלתה השגיאה הבאה:
[root@localhost *****]# internet --connect=smile
cp: cannot stat `/etc/resolv.conf': No such file or directory
which: no dhcpcd in (/sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin
:/usr/local/sbin)
which: no pump in (/sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/
usr/local/sbin)
Killing DHCP client for eth0 3718
Internet Systems Consortium DHCP Client V3.0.2
Copyright 2004 Internet Systems Consortium.
All rights reserved.
For info, please visit [url]http://www.isc.org/products/DHCP[/url]
sit0: unknown hardware address type 776
Listening on LPF/eth0/00:50:22:e3:cf:b4
Sending on LPF/eth0/00:50:22:e3:cf:b4
Sending on Socket/fallback
DHCPREQUEST on eth0 to 255.255.255.255 port 67
DHCPACK from 10.240.192.1
bound to 172.29.208.244 -- renewal in 95570 seconds.
DHCP client dhclient started succesfully.
which: no pptp-linux in (/sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/usr/local/sbin)
Killing PPtP client 10105
/tmp/iwiz/connect.sh: line 141: kill: (10105) - No such process
Fetching gateway using dhclient...
Gateway is 172.29.208.1
Adding route via 172.29.208.1
pns.inter.net.il: Host name lookup failure
ERROR: failed adding route via 172.29.208.1
ERROR: System call failed
מה יכולה להיות הבעיה?
