בעיה או אולי אי הבנה בAZUREUS
שלום,
יש לי את הדבר הבא:
ממה זה נובע?
ואיך להגדיל את הלימיט של הטורנטים?
[attachment deleted by admin]
מכיוון שההודעה חתוכה אז קשה להבין (למה אתה נותן SS חתוך ?!?)..
בכל מקרה אני מניח שאתה מוריד כמה קבצים בו"ז מאותו TRACKER פרטי, ובגלל הסטטוס של היוזר שלך שם נמוך, יש מגבלה שאתה יכול להוריד רק דבר אחד בו זמנית ממנו.
זה גודל ככל שאני משתף יותר?
עריכה:
תודה רבה אבל 10 דקות בFAQ פתרו לי תבעיה,
אם מישהו נתקל אז שיהיה פה:
Why do I get a "Access denied - Wait time in effect" error ?
From the time that each new torrent is uploaded to the tracker, there is a period of time that some users must wait before they can download it.
This delay in downloading will only affect users with a low ratio, and users with low upload amounts.
Ratio below
0.5
and/or upload below 4GB delay of
48h
Ratio below
0.6
and/or upload below 5GB delay of
32h
Ratio below
0.7
and/or upload below 6GB delay of
16h
Ratio below
0.8
and/or upload below 7GB delay of
8h
"And/or" means any or both. Your delay will be the largest one for which you meet at least one condition.
In your particular case, both your ratio of 0.31 and your total uploaded of 0.43 GB imply a delay of 48 hours.
This applies to new users as well, so opening a new account will not help. Note also that this works at tracker level, you will be able to grab the .torrent file itself at any time.
N.B. Due to some users exploiting the 'no-delay-for-seeders' policy we had to change it. The delay now applies to both seeding and leeching. So if you are subject to a delay and get the files from some other source you will not be able to seed them until the delay has elapsed.
Why do I get a "Access denied - Torrents Limit exceeded " error ?
This is part of the "Slot System". The slot system is being used to limit the concurrent downloads for users that have ratio below 0.85
In detail:
Users with ratio < 0.5have only 1 download slot available
Users with ratio < 0.6 have only 2 download slots available
Users with ratio < 0.7 have only 3 download slots available
Users with ratio < 0.85 have only 4 download slots available
Users with ratio > 0.85 have unlimited download slots
עריכה 2: ;)
לרוב כן.. תקרא את ה FAQ של האתר שאתה נמצא בו..
סליחה שאני מתפרץ לדלת פתוחה, אבל בתור משתמש של AZUREUS עד לפני שבוע אני מרשה לעצמי.
אני רוצה להמליץ לכם על תוכנה קלה, פשוטה, ידידותית וחינמית.
µTorrent
* Multiple simultaneous downloads
* Smart bandwidth usage
* File level priorities
* Configurable bandwidth scheduling
* Global and per-torrent speed limiting
* Quickly resumes interrupted transfers
* UPnP support (WinXP only)
* Supports popular protocol extensions
* Trackerless support (Mainline DHT)
* Localized to different languages
* Typical memory use less than 6 MB
* Incredibly small: 115 KB
http://utorrent.com/
מזכירה מאד את AZUREUS אבל צורכת ממש מעט זכרון (ולא תלויית JAVA...)
תנו לה נסיון ובאמת לא תחזרו ל-AZUREUS חזירת הזכרון.
בהצלחה. :)
מצטרף להמלצה, כמו כן יש טראקרים שחסמו את BITCOMET וממליצים על uTorrent.
מה זה טראקר
TRACKER זה השרת שמתאם את ההורדות בין כל ה CLIENTS שמורידים את אותו תוכן מאותו מקום.
וזה בסדר, המליצו מיליון פעם על UTORRENT, כל אחד ומה שהוא אוהב...
ברור.
רק תן לי סיבה אחת במה AZUREUS יותר טוב חוץ מזלילת זכרון ושימוש ב-JAVA?
נו, מה אנחנו ילדים.. זה גם עניין של הרגשה ושל מה אתה רגיל...
בכל מקרה, ל AZAREUS יש הרבה יותר PLUGINS שימושיים, כמו RSS FEED READER (הורדה אוטומתית של דברים לפי פילטרים), AUTO SPEED LIMIT שמשנה לך את מהירות ה UPLOAD לפי העומס על הקו, ועוד הרבה (שימושיים, לא סתם).
בן אדם זה היה זריז.
ומה? אנחנו לא ילדים?
לבריאות שיהיה לך.
