תקוע ב-Painkiller כנסו לפרטים
בשלב הזה
לא הבנתי מה לעשות איך אני הורג את המפלצת הענקית
כל פעם אני הורג את כל הרוחות ואז אני מקבל את הראייה המיוחדת
פשןט תמשיך ותמשיך עד שהיא תמות........ ניראה לי שאתה חייב להיות במצב של ה"ראייה המיוחדת" עד שהוא מת.
אני הורג את כל השדים ואחר כמה זמן זה נכנס לראייה המיוחדת
ורואים את lucyfer
אתה יכול להסביר לי בקצרה איך הורגים אתו
Part 01
Grab the ammo beside you and start walking as some enemies appear around you.
Ignore them and grab the ammo boxes as you continue onward, then grab some
armor from a secret area by the fire on your left. Grab more ammo from the
trenches up ahead and take the ammo from the left path, then grab some health
from the middle path. Return to the fork and take the right path [if you're
facing the middle path at the time] to escape the trenches.
Continue past the dinosaur bones as you take more ammo, then grab the health by
the small building to your left before heading up the road. Collect more ammo
as you go [including some in the building to your right], then approach the
Titanic up ahead and head left for some more ammo.
Now find a location and just keep killing the enemies [when the red ghosts
appear, you're close] until the battle with Lucifer begins.
Part 02
Jump left to dodge Lucifer's slashes, then attack him until he throws his sword
into the air.
Meteors start falling from the sky at this point and you need to find one and
shoot it INTO Lucifer. Keep shooting meteors into him until he eventually
throws his sword right at you. Now shoot the sword INTO him just like you did
with the meteors to end the battle. [if you took too long in any part of the
battle, then you'll have to fight off a few more ghosts before you get to
battle Lucifer again.]
Follow your arrow after the battle to finish the stage and see one of the TWO
endings to the game.
