הודעה בעליית מחשב לאחר התקנת ווינדוס 98SE
היי! התקנתי ווינדוס 98 SE וכאשר המערכת העולה קיימת הודעה זו ולאחר מכן אני אמור ללחוץ אינטר ואז היא עולה ,הנה תוכן ההודעה:
cannot find adevice file that maybe needed to ran windows or a windows application/ the windows registry or system INI file nefers to this device file bat the device file no longer exists
if you deleted this file on purpose try unistalling the associated application using its uninstall or setup program . if you still want to use the application associated wite this device file try reinstalling that application to replace the missing file
vnetbios.vxd
press any key to continue
תודה רבה!
Try this:
<Start>
<Run>
type "regedit"
with "My Computer" highlighted, choose:
<Edit>
<Find>
type "vnetbios.vxd
choose "Find Next"
when it finds a line that says something like:
"Static Vnetbios.vxd" choose:
<Del> and confirm with:
<Y>
Then <F3> to continue searching
Repeat for next occurrence, until Search has finished.
<File>
<Exit>
Shutdown system as normal, then power down (if not off).
Power up and observe no VNETBIOS.VXD message.
