FIRMWARE חדש לH10 - גירסה 2.51
ה FIRMWARE הוא לגירסאות הUMS של הH10 ומתעדכן דרך IRIVER PLUS
שינויים ותיקונים:
[Added functions]
1. Added AB repeat function. This function is activated or inactivated through "SETTING" -> "Extra" -> "A-B Repeat".
2. Added Study mode. This function is activated, inactivated, or configurable through "SETTING" -> "Extra" -> "Study Mode".
3. Alphabetical sort of file names in TEXT, PHOTO, and BROWSER modes.
4. Added a function to memorize a previously selected item in MUSIC mode.
5. Added a function to remove items in Quick List one by one.
[improvements]
1. Increased the number of supported files in TEXT and PHOTO modes.
2. Displays a marker to show the current songs in MUSIC and BROWSER modes.
3. Improved the playback function in BROWSER mode to play songs across the folders.
4. Improved the UI speed of removing a file in RECORD mode.
5. Improved Quick List.
6. Changed the icon showing 'wait': clock -> sand clock.
7. Always displays "Exiting" notification when the player is being shut-down.
8. Renames an existing file before a recording to avoid an overwriting.
9. Improved the scroll behavior in TEXT mode to achieve continuous scroll when a user keeps pressing [next]/[back] keys.
10. Displays a starting message for a slide show in PHOTO mode.
11. Improved the battery gauge.
[bug fixes]
1. Fixed a bug that dropped several music tracks in shuffle-playback mode.
2. Changed the behavior of going back to previous tracks in shuffle-playback mode so that a user can also get another randomized order.
3. Fixed a bug that generated unused files in a recoding.
4. Fixed a problem that the backlight was not turned off even after the period specified by the backlight timer.
5. Fixed a bug that the backlight was sometimes illuminated or turned-off by itself.
6. Fixed a problem that page-up function is not available for specific text files.
7. Fixed a problem when displaying JPEG image that is smaller than LCD size.
8. A JPEG-related fix (I could not translate this).
9. A JPEG-related fix (I could not translate this).
10. Fixed a problem that a player could not display lyrics embedded in MP3 files when the lyric data is large in size.
http://www.misticriver.net/showthread.php?t=30975
לא הבנתי מה זה ה A-B REAPEAT, מישהו יודע?
אתה קובע לו בשיר נקודת התחלה (A) ואז לוחץ עוד פעם כדי לקבוע נקודת סיום (B) ואז זה חוזר על מה שבין A-B בלופ.. (בשביל ללמוד שפה נגיד.. אז זה חוזר על קטע מסויים הרבה פעמים עד שלומדים.)
superman תודה על העדכון
מהירות התפרטים ובמיוחד הBROWSER השתפרה פלאים, תוקן גם האינדיקטור של הבטריה נראה אם הוא יהיה יותר מדויק הפעם :)
יש למשהו מושג למה הiriver plus אומר לי שמותקנת לי הגרסא האחרונה, כשלמעשה מותקנת לי גרסא ישנה ( 2.05 ) ?
( יש לי H10 5 ג'יגה אירופאי )
מוזר לי זה לא עשה בעיות...
האם תוכנת ה IRIVER PLUS שלך מעודכנת?
תבדוק במכשיר אם יש לך בSETTINGS אפשרות של עדכון ROM ? או שאולי יש שם קובץ מעדכון קודם שמונע.. או שהוא שתל את הקובץ ... תבדוק
התוכנה אומרת שהיא מעודכנת, אם היא דוברת אמת אין לי מושג ( גרסא 1.2.2.0 )
אין אפשרות כזו, ושום סימן לקובץ תקוע
משהו יודע קצת על iriver plus 2?
גרסת התוכנה בסדר כמו אצלי...
הIRIVER+2 נועד למכישרים H10 אחרים כמו H10 20GB אם אני לא טועה...
זה לא יעבוד עם H10
זה רק אצלי או שהשאפל יותר גרוע ממה שהוא היה?
הבעיה שלי נפתרה מעצמה, פשוט חיכיתי כמה שעות והוא מצא את העדכון לבד
סוףסוף זה מהיר באמת! :xyxthumbs:
בבקשה :), ואכן המהירות הכללית של המכשיר שופרה פלאים, כל הכבוד IRIVER :yelclap:.
עוד מישהו מרגיש שהFW החדש שינה את העוצמה של הFADE IN ?
אצלי יש לי הרגשה שה FADE בכלל לא עובד :s05:
קראתי באיזה דיון בMISTICRIVER ומשהו רשם שם שהFADE םחות חזק או משהו כזה
כן זה גם מה שאני מרגיש, מוזר.
עריכה: כל פעם שאני מדליק את הנגן הוא כותב לי SYSTEM INITIALIZING - זה תקין ? לעוד מישהו הוא עושה את זה ?
גם אצלי זה ככה, וזה רק אצלי או שהשאפל גרוע?
נראה לי שרק אתה משתמש בשאפל ::)
