הגרפיקה של XBOX360 VS PS3
מה אתם אומרים מי יותר טובה?
עוד שאלה לאיזה כרטיס גרפיקה שלהם מתשווה כיום?
הנה מאמר
Apples to Apples on Graphics?
The Xbox 360's ATI graphics core also throws a wrench into our graphics comparison since it uses a new-fangled Unified Shader Architecture that mixes up pixel- and vertex-pipelines and makes comparison to older video card technology very difficult. The Xbox 360 graphics core may have 48-pipelines, but we don't know how powerful they are compared to dedicated pixel and vertex pipelines.
The PlayStation 3 has a pretty strong Nvidia graphics processor, but you can see how Sony may be afraid of the specification sheet comparison by the pipeline number conveniently omitted from the PS3 graphics specifications. We're guessing that the RSX graphics processors has a traditional, non-unified shader engine, so it likely has a smaller total "pipeline" number than the ATI chip. Even if the RSX's normal pipelines are more powerful than the Xbox 360's pipes, Sony doesn't want to risk printing a lower "pipeline" number since people won't understand that it isn't an apples-to-apples comparison.
So how many traditional pipelines does the RSX have? Sony has revealed that the RSX GPU has a 550MHz core clock and has over 300 million transistors. Sony has also stated that the chip is more powerful than two GeForce 6800 Ultra cards put together. Your first guess might be that Nvidia simply doubled the pipeline number on the 6800 Ultra to make the RSX, but you also have to remember that the Ultra only clocked in at 400MHz. If the "double" performance measurement is based on fill-rate performance rather than hardware, the clock speed increase up to 550MHz is clear sign that the hardware improvement isn't from a pure doubling of pipelines. We're guessing that the actual pipeline count is going to be at 24, which is about right for 300 million transistors and, at 550MHz, has just a slightly larger fill-rate than two GeForce 6800 Ultras clocked at 400MHz. Since the GeForce Ultra had 6 vertex pipelines, the RSX likely has 6 more vertex pipes in addition to the 24 pixel pipelines.
הכרטיס של XBOX360 יותר טוב אבל המעבד של 6 ליבות(!!!)של PS3+הזיכרון איכותי וטוב יותר
בכלל לXBOX360 יש את הליבה של הכרטיס הזה:
ATI X1800XT
ולPS3 יש משהו מאוד דומה לזה:
GEFORCE 7800GT SLI
ATI X1800XT
GEFORCE 7800GT SLI
אתה מדבר פה כאילו שתי כרטיסי 7800GT במכשיר הזה?
ואו זה קטלני ביותר
אני חושב שפס3 ינצח יש לו תמשחקים היפים שלו ואני חושב שNVIDIA עושה תעבודה יותר טובה במשחקים לעומת ATI אני חושב שהם יותר טובים לעריכות
פליסטיישן ירוויח יותר לפי דעתי עדיף על האקס בוקס פי כמה וכמה כולם כבר מיתקוננים להכין מיסחקים ל 3 יהיה מישחקים יותר יפים ויותר מישחקים
