תקוע ב-HL2 בשלב שצריך להרוס מסוק כזה עם בזוקה...
יש כזה שלב שמורידים אותך עם מגנט ענקי ואתה בתוך האוטו (באגי), אז בדרך יש מין עמודים כאלה שצריך לכבות ואז מגיעים למחנה כזה שנותנים לך בזוקה ואתה צריך להרוס מסוק, אז הרסתי אותו וכיביתי את כל העמודים ואין לי מושג מה לעשות עכשיו.
Someone will tell you to go to the basement, so do so. You'll get a short
description of the RPG, and you'll be the lucky one to use it. It's time for
a battle now. With the RPG, you'll have to take down the Gunship. If you're
out of ammo, look around for rockets. You'll find plenty. A medic will always
follow you, in case you get hurt. When the Gunship is destroyed, head back to
the basement, and you'll be thanked. Go to your buggy, and the villagers will
open the gate. Leave the town and keep going.
*Loading*
See the crane? You need to enter it. Go there, and take out anything that
wants to kill you. Once you are in the crane, more Combines will shoot at
you. You can pick up a container, and drop it on them. Find a bridge that's
holding you back from going there with your buggy. Flip it over by throwing
a container at it. Pick up your buggy, and place it somewhere near the bridge.
Go down, but don't enter the buggy yet. Go to the new area, and kill the
Combines inside the building. Find a lever here to open the gate. Get in your
buggy, and get driving. Find a ramp, and use it to jump through the windows.
Continue to drive, and watch out for the Gunship. You'll end up in a tunnel.
*Loading*
Continue the driving, and search the houses if you want. Drive, until you see
a field that you can't drive through (just like the ones near the trains in
chapter 2). Follow the cables, and you'll see it ends up near a car. The car
is on a hill, and the blocks near the wheels are there to prevent the car from
rolling down. Use your Gravity Gun to get rid of the blocks, and the car will
start to drive. This'll cut the power of the field, and you can go through. Do
so.
*Loading*
See all the houses? The biggest one is the one you'll need. On the upper
floor (reach it by stacking up some stuff near the stairs), you can find a
Crossbow. Once you found it, a Piggy Tail Zombie will appear, so I suggest to
leave as soon as you got it. See the bridge? Good. There are even more fields
here, so you can't go there with your buggy for now. Find a door near the
bridge, and enter it. Follow the path.
*Loading*
The idea is to get to the other side of the bridge. Explore for goodies, but
you'll mainly need those on your way back. Notice the rockets and health
packs you obviously don't need at this moment. Once you reached the other side
of the bridge, you'll end up in a room with a field. Kill the Combines in
here, and use your Gravity Gun to pull the plug out. This will cut the power,
and all the fields are down. Also hit the switch. A Gunship will appear, so
head back to the middle of the bridge. There is a crate with rockets here, and
this should be enough to take the Gunship down. Once you did, head back to the
buggy. You'll have to take a different route. Just keep going.
*Loading*
Go go go! When you are outside, you'll see Antlions attack a Piggy Tail
Zombie. Try to avoid fighting, and just find your way back to the buggy.
You'll probably have to kill a few Antlions and Combines though. Take the
buggy to the bridge, and follow the trail. A train will appear on the other
side, but if you use turbo, you should be able to make it without getting hit.
Follow the path, and enter the tunnel to end this chapter.
תקרא מה שכתוב.
נתתי לך תקציר שיעזור לך לסיים את כל ה-chapter הזה :)
תודה! :xyxthumbs:
כולכם קניתם חשבון STEAM???
כנראה :smile1:
או שמשתמשים ב steam down (מה שאני הולך לעשות :jump: )
HL2 ובמיוחד CS שווה את הקניה.
שווה קנייה ביותר... רק חבל שעם כל עדכון של סטים יש מיליון באגים חדשים... למרות שהעדכון האחרון *טפו טפו* לא עושה יותר מדי בעיות...
VALVE חברה שאני מוכן להוציא מכספי על המחשקים שלה,שווה כל שקל, HL2 ובמיוחד CSS.
אם יש משחק שבאמת שווה קניה,זה HL2..פשוט משחק ענק
ושלא נדבר על כך שאתה מקבל עם המשחק גם CS:S שהוא בפני עצמו שווה קנייה.
ואתה גם מקבל HL2:DM ובקרוב גם את HL2:TLC
ואם אתם יכולים להרשות לעצמכם לשלם 50 דולר לחבילת הSILVER,אז בכלל חבל"ז,כי אז אתם מקבלים:
HL2
HL2:DM
CS:S
DOD:S
HL2:TLC
HL:S
+כל המשחקים הקלאסיים של וואלב ושל חברות צד שלישי [HL,HL:OF,HL:BS,CS1.6,CS:CZ,CS:CZ:TDS,DOD,R,וכו']
ובקרוב גם את HL:DMS [DEATHMATCH SOURCE[
במחיר של 50 דולר אתם מקבלים יותר משחקים ממספר הדולרים ששילמתם :P
