טלאי 1.03 עבור Battlefield 2 סוף סוף שוחרר!
  • תגובות 34
  • צפיות 2.9k
^^^ LOL
New Features
* Stats compare - view the extended stats details for any other player in your BFHQ simply by double-clicking on their name on the leader board or using the new search feature!
* Server Favorites and History - find your favorite servers that much easier. No more searching for them through the main server list!
* Nickname Prefix - Add and change your clan tag to your account name at will. No more creating alternate account names to cover the changes in your competitive lifestyle!
* Supply Drop Icons - Supply drops now appear on the main map and within the 3D Map. Find that elusive supply drop much, much quicker!
* Points for Destroying Command Objects - players now receive points for destroying the commander's toys. Special Forces players rejoice!
* Server Reserved Slots - Server Operators can now set aside slots for their admins to join a full server at any time!
* Vehicle Passengers - the names of players in a vehicle with you are now displayed when you enter or change seats.
* Countermeasures - a reload bar has been added for vehicle countermeasures. You'll always know now when you can set off that next flare!
Tweaks
* Point Farming changes - DICE has implemented functionality that makes it significantly harder to point farm on Ranked Servers.
* Mod Support - Mods now work properly with the Dedicated Server! Additionally, the game will automatically switch mods when joining a server that is running a mod you have installed but do not have activated.
* Map tweaks - Spawn menu map and Commander maps now scale based on the size of the level being played (16, 32 or 64 players). Mini-map also scales automatically based on the vehicle type you are using (manual changes to zoom levels are remembered as well).
* Commander scoring - No more TKs from Artillery!
* Vehicle tweaks - No more accidental kills from bumping a friend with your tank (try to avoid hitting him at speed though) and no more struggling uphill in an APC. Also no more improper TK allocation from vehicle explosions.
* Auto Team Balance tweaks - Commanders and Squad Leaders now immune to team switch.
* Anti-Air Missiles - These are now much more effective against fast-movers.
and much, much more!
מוזר, אין עוד קישור באתר הרשמי :nixweiss:
http://www.eagames.com/official/battlefield/battlefield2/us/downloads.jsp
:pissed: :pissed: :pissed: :pissed: :pissed:
[attachment deleted by admin]
w00t! זה פשוט מעולה זה עידכון שכל כך היה נחוץ!
Favorites והאפשרות לשנות את הניק זה פשוט מעולה!
איך הצלחת להוריד כבר ???? זה מוריד לי על איזה 3Kbps :pissed:
OMFG!!!!!11111111111111Oneoneoneoneoneoneoneoneעחאד
[me=R0cKF0rD]is מקריח HARD
[/me]
אין איזה לינק קצת יותר מהיר?
אתה צריך הרד דיסק נוסף בשביל ה-SWAP
יש לי שני הרד-דיסקים כל אחד עם שני מחיצות ומלא מקום פנוי !
הפאצ' הזה דפק לי עכשיו את המשחק לגמרי ! :bash::kopfpatsch: לא שלפני זה הוא עבד מעולה :P
קולה ז*ן...
נסה להסיר את המשחק ולהתקין מחדש.
לא עבד?
תפרמט את המחשב, תתקין את הכל + את המשחק מחדש + הפאץ'.
לא עבד?
קח 5 מטרים אחורנית מהמחשב, שלוף את חוברת ההוראות של המשחק ותתחיל לקרוא מע"מ 1.
מי שאין לו עותק חוקי לא צריך את הפאט'צ הזה? ::)
הותקן בהצלחה. :xyxthumbs:
מלבד ה BFHQ, נראה שהכל רץ כמו שצריך... אני מאמין שבעוד יום-יומיים גם ה BFHQ יסתדר. לבינתיים כל עניין הדרגות די הזוי.
מרגישים קצת שיפור בFPS, לא ? (בסינגל פלייר)
לבעלי הגרסה הפרוצה אל תורידו למדתי מטעוית אין עדין פאץ פרוץ :kopfpatsch:
