חוות דעת על NEO4 של MSI
k8n 4 Neo Platinum (939)
בעיקרון הוא עולה 910 ב KSP
יש לו לדעתי את כל הפיצרים של GIGABYE K8NF-9
קצת יותר
אבל אני פשוט השגתי אותו ב 590 שקל
מה אתם אומרים עליו?
Model K8N Neo4 Platinum
CPU Supports Socket 939 for AMD® Athlon 64 FX / Athlon 64 processor
Supports up to 3500+, 3800+ Athlon 64 FX 53, or higher CPU
Chipset NVIDIA® nForce4 Ultra Chipset
- HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU
- HyperTransport supporting speed up to 1GHz (2000MT/s)
- Supports PCI Express x16/x1 interface
- Two independent SATA controllers, for four drives
- Dual Fast ATA-133 IDE controllers
- IEEE 802.3 NVIDIA MAC for 1000BASE-T
Main Memory Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs.
Supports a maximum memory size up to 4GB without ECC.
Supports 2.5v DDR SDRAM DIMM.
Slots One PCI Express x16 slot (supports PCI Express Bus specification v1.0a compliant)
One PCI Express x4 slots (support PCI Express x2 only)
One PCI Express x1 slots (support PCI Express Bus specification v1.0a compliant)
Four 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE An IDE controller on the NVIDIA nForce4 Ultra chipset provides IDE HDD/CD-ROM with PIO,
Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
On-Board SATA NV RAID supports 4 SATA II ports(SATA 1 to 4). Transfer rate is up to 300MB/s.
NV RAID (Software)
Supports up to 4 SATA and 4 ATA133 Hard drives
- RAID 0 or 1, 0+1, JBOD is supported
- RAID function available for ATA133+SATA H/D drives
Silicon Image's SATARAID5 (Software)
RAID 0 or 1, RAID5, RAID10, and JBOD groups are supported
Support up to 4 SATA devices connected to a single controller
Audio 7.1 channel audio codec RealTek ALC850.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN Supports dual LAN jacks
- 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY
- 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E8053
IEEE1394 VIA 6307 chipset
- Supports up to two 1394 ports. (Rear panel x1, pinheader x1)
- Transfer rate is up to 400Mbps
On-Board Peripherals On-Board Peripherals include:
- 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 Audio jack(5-in-1), coaxial/fiber SPDIF out
- 1 IrDA pinheader
- 1 D-Bracket2 pinheader
- 10 USB 2.0 ports (Rear x 4 / Front x 6)
- 2 RJ45 LAN jacks
- 2 IEEE 1394 connectors (Rear x 1/ Front x 1)
BIOS The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and
expansion cards of the board automatically.
The mainboard provides a Desktop Management Interface(DMI) function which records your
mainboard specifications.
Dimension 30.4cm(L) x 24.4cm(W) ATX Form Factor
Mounting 9 mounting holes.
לוח מעולה ללא ספק
אבל השגת אותו במחיר ממש זול וזה מעלה חשדות [מעניין מה עבר על הלוח הזה]
בכל מקרה תחדש
לוח מעולה
אבל המחיר מעלה מאוד חשד
אני יכול להשיג אותו במחיר נמוך אבל 590 זה נמוך מדי
משהו מסריח
לוח טוב אבל אחי מאיפה השגת אותו?מאיזו חנות?
אני לא חושב שאפילו אצל היבואן (אייבורי) אפשר להשיג את הלוח בכל כך זול
כן קניתי אותו מאייבורי
הם לא מוכרים אותו ליחידים
מכיוון שזה זול מידי והם לא רוצים שספקים יקנו את זה מהם ואז ימכרו יותר יקר
פשוט קניתי מהם מחשב שלם והם הציעו לי
בכל מקרה אני רגוע מבחינת החלקים מכיוון שאני קניתי לפני חצי שנה
מחשב ומהם לקחתי לוח אם
MSI k8n NEO PLATINUM 754
ב KSP הוא היה עולה810
שם לקחתי אותו באיזה 550
פשוט הם היבואנים
ובלי מילה רע טפו טפו טפו
המחשב עובד פיצוץ
לוח אם מעולה
יש לי אותו
נחמד מאוד גם גם לOC
בנוסף לאמינות והאיכות של MSI, לכרטיס קול האיכותי יחסית, לבאנדל הטוב ולהכול..
עם זכרונות TCCD הוא גם OC מצויין :beerchug:
אם זה כבר במחיר כזה טוב תבדוק באיזה מחיר אתה יכול להשיג את ה MSi K8N SLi Platinum
השבב קול שלו יותר איכותי (24Bit של Creative)
התוספת לא אמורה להיות משמעותית
:hi:
מסכים . . .
לוח מעולה, ובמחיר שאתה משיג אותו,לא הייתי לרגע מהסס!
בסדר גמור
תודה רבה חברים!!
