קובץ LOG של הנתב
שלום לכולם
רציתי לדעת איפה אני יכול למצוא מידע והסברים על קובץ ה-SYSTEM LOG שהנתב שלי (edimax) יוצר.
חיפשתי במדריך המסופק עם הנתב ולא מצאתי.
בינתיים אולי תוכלו לומר לי למה הכוונה ב-
Aug 12 14:58:32 pppd[7438]: Serial link appears to be disconnected.
Aug 12 14:58:47 pppd[22285]: pppd 2.4.1 started by root, uid 0
Aug 12 14:58:47 pppd[22285]: Using interface ppp0
Aug 12 14:58:47 pppd[22285]: Connect: ppp0 <--> /dev/pts/0
Aug 12 14:58:47 pppoe[22288]: Changed pty line discipline to N_HDLC for synchronous mode
Aug 12 14:59:18 pppd[22285]: LCP: timeout sending Config-Requests
Aug 12 14:59:26 pppd[22493]: pppd 2.4.1 started by root, uid 0
Aug 12 14:59:26 pppd[22493]: Using interface ppp0
Aug 12 14:59:26 pppd[22493]: Connect: ppp0 <--> /dev/pts/0
Aug 12 14:59:27 pppoe[22496]: Changed pty line discipline to N_HDLC for synchronous mode
Aug 12 14:59:58 pppd[22493]: LCP: timeout sending Config-Requests
Aug 12 15:00:06 pppd[22737]: pppd 2.4.1 started by root, uid 0
Aug 12 15:00:06 pppd[22737]: Using interface ppp0
Aug 12 15:00:06 pppd[22737]: Connect: ppp0 <--> /dev/pts/0
Aug 12 15:00:06 pppoe[22740]: Changed pty line discipline to N_HDLC for synchronous mode
Aug 12 15:00:15 udhcpd: Received a SIGUSR1
Aug 12 15:00:37 pppd[22737]: LCP: timeout sending Config-Requests
Aug 12 15:00:45 pppd[22951]: pppd 2.4.1 started by root, uid 0
Aug 12 15:00:46 pppd[22951]: Using interface ppp0
Aug 12 15:00:46 pppd[22951]: Connect: ppp0 <--> /dev/pts/0
Aug 12 15:00:46 pppoe[22957]: Changed pty line discipline to N_HDLC for synchronous mode
Aug 12 15:01:17 pppd[22951]: LCP: timeout sending Config-Requests
Aug 12 15:01:25 pppd[23157]: pppd 2.4.1 started by root, uid 0
Aug 12 15:01:25 pppd[23157]: Using interface ppp0
Aug 12 15:01:25 pppd[23157]: Connect: ppp0 <--> /dev/pts/0
Aug 12 15:01:25 pppoe[23162]: Changed pty line discipline to N_HDLC for synchronous mode
Aug 12 15:01:40 pppoe[23162]: PADS: Service-Name: ''
Aug 12 15:01:40 pppoe[23162]: PPP session is 20832
Aug
או לפחות חלק מהפקודות הללו. הסיבה שאני שואל היא שלפעמים אני לא מצליח להתחבר לאינטרנט ללא כל סיבה וזה אחד מהמקרים.
נראה לי לא קשור.. או שיש בעיות בקו, או בתשתית או אצל הספק..
