ATI Catalyst� 5.7 - דרייבר חדש!
ATI Catalyst 5.7 יצא לאויר העולם...
https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&folderID=27
מה חדש?
New Features
This section provides information on new features introduced in the latest release of the Catalyst Software Suite. New features include:
1080p Display Support Option
Catalyst Control Center Un-install Option
Catalyst 5.7 introduces support enhancement to the display support options found in the Digital Panel Properties of the Catalyst Control Center. This enhancement will offer a 1080p standard format option for a displays that are reporting incomplete or incorrect capabilities in their EDID information. This feature will be supported on ATI Radeon® X300 products and above, and will be supported under the Microsoft Windows XP, 2000 and the next release of the Windows XP Media Center Edition operating systems.
Catalyst 5.7 introduces a clean un-install option for the Catalyst Control Center. When a user chooses to remove the Catalyst Control Center, all desktop shortcuts, user defined profiles, and hotkeys will be completely removed from the system. All custom setting will need to be recreated when the Catalyst Control Center is installed once again.
Performance Improvements
Enhancements to our driver's internal memory management bring significant benefits to 64MB and 128MB framebuffer configurations in Catalyst 5.7.
The resulting performance gains are most apparent in high resolution, everything on modes, when running applications that use a significant amount of graphics memory. Examples include:
5-15% gains in 3DMark05 on some products
20-60% gain in Far Cry Regulator across multiple settings
25-60% gains in Half-Life 2 at 1600x1200 4xAA 8xAF
40-60% gains in UT2004 at 1600x1200 6xAA 16xAF
50-100% improvement in Comanche4 at 1600x1200 6xAA 16xAF
50-200% gains in certain ShaderMark tests at high resolution
עוד מידע על הדרייבר החדש:
http://www2.ati.com/drivers/Catalyst_57_release_notes.html
  • תגובות 61
  • צפיות 6.2k
שום דבר בנוגע לתיקון הפאקים בצללים ב-BF2?
:s05:
נשמע קצת מוגזם תוספת הביצועים...
שווה הורדה?
LOL
Geometry corruption or missing textures maybe noticed when playing the game for an extended period of time under Windows XP with an ATI Radeon® X800 XT installed
זה לא שזה משחק כל שהוא שהוא לא פופולארי או כרטיס מסך כמו 9100 ו9500 שכבר לא מיוצרים יותר
זה באטלפילד 2
והX800 שכל הזמן אומרים אחד לשני פה שהוא עדיף על ה6800GT
בעלי x800
תדאגו לריסטרט כל 30 דקות או שחווית המשחק שלכם לא תיהיה נעימה xD
שווה הורדה?
LOL
זה באטלפילד 2
בעלי x800
למה ריסטארט כל 30 דקות!?
משהו מוכן לתת לי לינק איפהה הורדה שהיא לא CCC נמצאת כי אני פשוט לא מוצא את זה שם...
מה זה CCC?
שווה הורדה?
זה יעזור לי עם 9600XT??
ולא הבנתי למה RESTART כל 30 דקות?
מה זה CCC?
Catalyst cantrol center
מציג את האפשרויות ביותר פירוט....
טוב אני פה אחכה לתגובות של אנשים שהתקינו את 5.7 כי לי אין הצלחה עם דרייברים אז אני אוריד רק לפי ההמלצות שלכם...
בבקשה כל מי שהתקין שיגיב פה לרעה או לטובה...
אני שמתי לב לשיפור בסאן אנדראס ו-BF2 היה יציבות FPS טובה יותר...9800pro.
אני מוריד ומחכה לתגובות, הדרייבר האחרון של 5.6 רק עשה לי בעיות בעיות ובעיות, למשל ב-GTA, אני מעדיף לחכות לביקורות של אנשים רק אחרי זה אני יתקין כי גם ככה  כל החרטה של שיפור בביצועים לא עושה עלי רושם.
הדרייבר דיי יציב...
עד עכשיו שיחקתי רק BF2 וממה שאני רואה יש שיפור קטן בביצועים, אבל בעית הטקסטורות עדיין לא נתפרה.
Radeon9800se
