Firmware חדש לEdimax 6114wg - V2.11
BR-6114Wg Firmware Version : 2.11
Edimax Web Site
Release Note ( BR-6114 WG )
2.11 2005.05.28
Fixed:
- The PPPoE's connect on demand function can not work properly.
- URL blocking enabled sometime will cause problem.
- Ftp ALG problem, sometime will cause connect failed.
- The current time is wrong.
- PPTP pass-through with cisco VPN router problem.
- PPPoE can not attach service name problem.
- Router will reboot when traffic over 30 Mbps (packet siz 64).
- URL blocking can't block subdirectory in URL or directory only.
- Can't filter MSN in IP filter problem.
- DDNS will registered LAN IP in l2tp mode problem.
- PPPoE compability with Philippine ISP.
Modify:
- Change concurrent conections from 1024 to 2048.
