איך התוצאות האלו ב PCMark05 בשביל המחשב הנייד?
System Configuration
General Information
Operating System Microsoft Windows XP 32-bit
DirectX Version 9.0c
Mobo Manufacturer IBM
Mobo Model 18349LG
AGP Rates (Current/Available) 1x / 1x, 2x, 4x
CPU Intel Pentium M 1497 MHz
Physical / Logical CPUs 1 / 1
MultiCore 1 Processor Core
HyperThreading Not Available
FSB 400 MHz
Memory 1008 MB
Display Information
Graphics Chipset Generic VGA
Driver Name Intel® 82852/82855 GM/GME Graphics Controller
Driver Version 6.14.10.4308
Video Memory 59 MB
Core Clock N/A
Memory Clock N/A
Hard Disk Information
Model HTE726060M9AT00
Connection IDE
Capacity 57.23 GB
Bus Type ATA
Benchmark Information
Program Version PCMark05 Revision 0 Build 1
Main Test Results
System Test Suite N/A
CPU Test Suite 2396
Memory Test Suite 1666
Graphics Test Suite N/A
HDD Test Suite 3725
Detailed Test Results
System Test Suite
HDD - XP Startup 6.72 MB/s
Physics and 3D 28.99 FPS
Transparent Windows 21.46 Windows/s
3D - Pixel Shader N/A
Web Page Rendering 2.18 Pages/s
File Decryption 36.81 MB/s
Graphics Memory - 64 Lines 159.52 FPS
HDD - General Usage 4.32 MB/s
Multithreaded Test 1 / Audio Compression 768.68 KB/s
Multithreaded Test 1 / Video Encoding 108.59 KB/s
Multithreaded Test 2 / Text Edit 31.58 Pages/s
Multithreaded Test 2 / Image Decompression 8.98 MPixels/s
Multithreaded Test 3 / File Compression 1.7 MB/s
Multithreaded Test 3 / File Encryption 9.43 MB/s
Multithreaded Test 3 / HDD - Virus Scan 16.78 MB/s
Multithreaded Test 3 / Memory Latency - Random 16 MB 5.9 MAccesses/s
CPU Test Suite
File Compression 6.55 MB/s
File Decompression 83.71 MB/s
File Encryption 38.07 MB/s
File Decryption 36.99 MB/s
Image Decompression 17.73 MPixels/s
Audio Compression 1581.84 KB/s
Multithreaded Test 1 / File Compression 3.32 MB/s
Multithreaded Test 1 / File Encryption 19.26 MB/s
Multithreaded Test 2 / File Decompression 21.47 MB/s
Multithreaded Test 2 / File Decryption 9.25 MB/s
Multithreaded Test 2 / Audio Decompression 315.43 KB/s
Multithreaded Test 2 / Image Decompression 4.47 MPixels/s
Memory Test Suite
Memory Read - 16 MB 1792.91 MB/s
Memory Read - 8 MB 1945.29 MB/s
Memory Read - 192 kB 3275.46 MB/s
Memory Read - 4 kB 8104.31 MB/s
Memory Write - 16 MB 1591.62 MB/s
Memory Write - 8 MB 1591.51 MB/s
Memory Write - 192 kB 2934.14 MB/s
Memory Write - 4 kB 7763.03 MB/s
Memory Copy - 16 MB 1567.24 MB/s
Memory Copy - 8 MB 1552.06 MB/s
Memory Copy - 192 kB 2803.22 MB/s
Memory Copy - 4 kB 6215.27 MB/s
Memory Latency - Random 16 MB 6.47 MAccesses/s
Memory Latency - Random 8 MB 6.8 MAccesses/s
Memory Latency - Random 192 kB 146.58 MAccesses/s
Memory Latency - Random 4 kB 497.88 MAccesses/s
Graphics Test Suite
Transparent Windows 18.15 Windows/s
Graphics Memory - 64 Lines 159.67 FPS
Graphics Memory - 128 Lines 133.57 FPS
WMV Video Playback 24.84 FPS
3D - Fill Rate Multi Texturing 720.45 MTexels/s
3D - Polygon Throughput Multiple Lights 3.05 MTriangles/s
3D - Vertex Shader N/A
HDD Test Suite
HDD - XP Startup 6.66 MB/s
HDD - Application Loading 5.15 MB/s
HDD - General Usage 4.33 MB/s
HDD - Virus Scan 60.37 MB/s
HDD - File Write 32.92 MB/s
