יש לי בעיה עם הגלישה באינטרנט
בשעות מסויימות הגלישה איומה
אני עושה trace לאתרים בארץ ובחו''ל ותמיד מקבל Request timed out
Tracing route to www.tapuz.co.il [212.150.54.150]
over a maximum of 30 hops:
1 22 ms 19 ms 19 ms ln-ta-212.199.28.244.012.net.il [212.199.28.244]
2 19 ms 17 ms 19 ms ta-212.199.28.30.012.net.il [212.199.28.30]
3 85 ms 95 ms 20 ms fe-ta-212.199.28.78.012.net.il [212.199.28.78]
4 47 ms 41 ms 119 ms su-ta-212.199.28.206.012.net.il [212.199.28.206]
5 22 ms 19 ms 42 ms sa-pt-212.199.26.35.012.net.il [212.199.26.35]
6 71 ms 79 ms 55 ms 212.150.38.25
7 20 ms 22 ms 20 ms 212.29.206.46
8 33 ms 33 ms 19 ms 212.29.206.213
9 418 ms 262 ms 121 ms 62.90.133.202
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * ^C
Tracing route to www.nforce.nl [62.212.84.61]
1 29 ms 18 ms 20 ms ln-ta-212.199.28.244.012.net.il [212.199.28.244]
2 21 ms 126 ms 22 ms ta-212.199.28.30.012.net.il [212.199.28.30]
3 72 ms 75 ms 79 ms fe-ta-212.199.28.78.012.net.il [212.199.28.78]
4 74 ms 75 ms 80 ms ja-ta-212.199.28.66.012.net.il [212.199.28.66]
5 76 ms 181 ms 122 ms POS1-0.GW5.FFT3.ALTER.NET [146.188.70.5]
6 97 ms 184 ms 73 ms 425.at-6-1-0.CR1.FFT3.ALTER.NET [149.227.16.229]
7 94 ms 75 ms 73 ms so-0-0-0.XR2.FFT4.ALTER.NET [149.227.31.161]
8 73 ms 103 ms 76 ms so-1-1-0.TR2.FFT1.ALTER.NET [146.188.8.146]
9 164 ms 73 ms 75 ms POS2-0.BR2.FFT1.ALTER.NET [146.188.6.114]
10 86 ms 95 ms 154 ms if-3-2.core2.FR1-Frankfurt.teleglobe.net [80.231
.65.25]
11 97 ms 98 ms 194 ms if-4-1.core1.FR1-Frankfurt.teleglobe.net [80.231
.64.13]
12 96 ms 166 ms 204 ms if-2-0.core2.AD1-Amsterdam.teleglobe.net [80.231
.81.1]
13 176 ms 97 ms 132 ms Vlan2.msfc1.AD1-Amsterdam.teleglobe.net [80.231.
82.4]
14 200 ms 118 ms 102 ms ge-1-0.r1.tc2.nl.leaseweb.net [80.231.82.130]
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 ^C
Tracing route to www.fresh.co.il [82.80.248.160]
1 58 ms 35 ms 20 ms ln-ta-212.199.28.244.012.net.il [212.199.28.244]
2 17 ms 19 ms 19 ms ta-212.199.28.30.012.net.il [212.199.28.30]
3 22 ms 20 ms 22 ms fe-ta-212.199.28.78.012.net.il [212.199.28.78]
4 43 ms 19 ms 20 ms su-ta-212.199.28.206.012.net.il [212.199.28.206]
5 18 ms 20 ms 19 ms sa-pt-212.199.26.35.012.net.il [212.199.26.35]
6 18 ms 52 ms 126 ms bzq-179-28-225.cust.bezeqint.net [212.179.28.225
7 21 ms 66 ms 19 ms bzq-25-64-146.cust.bezeqint.net [212.25.64.146]
17 * ^C
מה יכולה להיות הבעיה זה מתחיל לעצבן אותי כבר...?
Tracing route to www.microsoft.com.nsatc.net [207.46.198.30]
  1    17 ms    17 ms    20 ms  ln-ta-212.199.28.244.012.net.il [212.199.28.244]
  2    16 ms    20 ms    19 ms  ta-212.199.28.30.012.net.il [212.199.28.30]
  5    48 ms    49 ms    48 ms  pal5-goldenlines-3-il.seabone.net [195.22.205.25
  6   207 ms   211 ms   210 ms  ash1-new2-racc1.new.seabone.net [195.22.216.139]
  7   181 ms   176 ms   179 ms  microsoft-2-us-ash1.ash.seabone.net [195.22.206.
26]
  8   179 ms   180 ms   182 ms  gig2-1.core2.ash1.ntwk.msn.net [207.46.46.130]
  9   236 ms   235 ms   237 ms  pos3-1.tuk-76cb-1a.ntwk.msn.net [207.46.34.53]
10   237 ms   242 ms   235 ms  pos1-0.iuskixcpxc1202.ntwk.msn.net [207.46.36.14
6]
11   244 ms   242 ms   243 ms  pos1-0.tke-12ix-1b.ntwk.msn.net [207.46.155.5]
12   237 ms   242 ms   238 ms  po12.tuk-65ns-mcs-1b.ntwk.msn.net [207.46.224.15
2]
27  po12.tuk-65ns-mcs-1b.ntwk.msn.net [207.46.224.152]  reports: Destination ne
t unreachable.
Trace complete.
בסדר, אני אצטרך קצת יותר פרטים כאן, מפרט של המחשב, ציוד רשת בשימוש (נתבים, מודמים וכו'...), כמו כן האם היו לך שיחות עם מוקד התמיכה שלהם בעבר, אם כן, מה הם יעצו לך לעשות ?
פנטיום 4
1.6
אינטל -לוח אם
512 זיכרון
XP SP1 מעודכן
מחשב נקי ממרגלים ווירוסים !
אין רשת או נתב רק מודם פנימי של ITEX
התקשרתי אל התמיכה והם לא עזרו במיוחד
אפשר לומר שהם לא עזרו בכלל לא אמרו כלום סתם בדקתי פינגים לאתרים
ועשיתי trace וזהו
הם כאילו הכל בסדר....
טוב, האמת התעניינתי איך התוצאות ייראו אצלי במחשב, ספק שונה, יש אצלי רשת ללא נתב ואותן תוצאות, אך אין לי בעיית גישה כלשהי לאתרים הללו... אני חושב שזה נורמלי ואין הבעיה טמונה ב-Trace.
גם לי היו הרבה בעיות שכאלה. בעיות מוזרות, שנראות לא קשורות לזמן, ציוד או ספק אינטרנט. ראיתי את אותן בעיות אצל הרבה אנשים. המסקנה היחידה שהצלחתי להגיע אליה היא שבארץ האינטרנט פשוט חרא, כי ספקי האינטרנט הם חרא שלא משקיעים בפיתוח התקשורת שלהם, אלא בפרסום.
ברוך הבא למועדון.
