מתלבט בין שני אוזניות לצורכי גיימינג.
שלום אני מתלבט בין שני אוזניות האחד זה
Sennheiser PC160
* Gives you the unique 3-D, 360° sound experience
sound from all sides including above and below
* Adjustable headband for a perfect fit
* Adjustable, bendable and pivotable microphone makes
the voice more clear and increases comfort and flexibility
* Noise-canceling microphone provides high speech clarity
and voice recognition by filtering out noise around you
* With the in-line volume control and microphone mute
switch, keep sound at the right level or have a side
conversation in privacy
* Equipped with a single-sided extra thick cable for
maximum robustness
Technical data
Headphones
Frequency response .............. 15 23,000 Hz
Impedance............................... 16 Ω
Sound pressure....................... 114 dB
Cable length............................ 3 m / 10 ft
Connector plug ....................... 2 x 3.5mm for PC/Laptop
Microphone
Frequency response ............... 80 Hz 15,000 Hz
Pick-up pattern....................... Uni-directional
Sensitivity .............................. -38 dB
Impedance............................... ~2 kΩ
Compatibility .......................... With virtually any sound card
Accessories Included:
* Microphone windscreen
Optional:
* Replacement leatherette headband pad
* Replacement ear cushion
* Developed for and with leading
professional eSport Gamers
* Open air speaker system, like that
of Sennheiser open headphones,
provide the ultimate pc gaming
sound, as close to real life as it gets
* XXL padded ear caps for extreme
comfort, even after all night gaming
sessions
לבין האוזניות של Icemat Audio - Siberia
Technical info:
HEADPHONE:
Frequency resp: 18-28.000 Hz
Impedance: 40 Ohm
SPL@1kHz, 1V rms: 99 - 104dB
Cable length: 1,0+1,8=2,8m.
Jack: 3,5 mm. + 6,3 mm. converter.
MICROPHONE:
Frequency Response: 80-15.000 Hz
Pick-up pattern: Sensitive uni-directional
1V/P@1kHz: -38dB
ויש עוד דגם שמזה דיי ירדתי אבל בכל זאת :
Sennheiser PC150
Frequency Response: 18Hz - 22,000Hz
Nominal Impedance: 32 ohms
Sensitivity: 114 dB SPL
Connector: 2 x 3.5mm
Microphone Type: Uni-directional
Microphone Impedance: 2k ohms
Microphone Frequency Response: 80Hz - 15,000 Hz
מה הכי כדאי לי??
אני שוב יציין שהאוזניות הם לצורכי גיימינג במיווווחחדדד ואני חושב שסראונד זה חשוב בשביל שתדע בדיוק איפה היריבים אבל לא יודע =\
אז בבקשה עזרה. תודה מראש D:
עדיף לך לתת לנו את התקציב שלך וכך נוכל לתת לך עזרה בבחירת האוזניות, בלי שום קשר המפרט הטכני של האוזניות לא אומר כלום על יכולתיו ואיכותיו אני ממליץ לך ללכת לשמוע את האוזניות שאתה רוצה לקנות, או לפחות לשמוע ביקורות רבות וטובות לפני...
בעיקרון אני קונה בארצות הברית אבל תראו התקציב בארץ הוא עד 400-450
בחו"ל הוא 100$ אבל הבעייה היא שאני חייב חנות פיסית בניו יורק =\ ההורים שלי לא מרשים להביא לי תכרטיס אשראי..
תודה מראש D:
נ.ב
סופסוף מישהו הגיב ^^
לך לB&H בניו יורק(זה חנות ממשית) קנה שמה את הסנהייזר 280 פרו הוא תותח(אני שונא לחזור על עצמי)
אין ספק ש280 פרו יכול להתאים לך, אבל ההיתי ממלית לך לבדוק אץ הסוני V6 גם מומלצות מאד.
בקשר לחנות, אם אני לא טועה זאת חנות יהודית והיא מאד יקרה.
הוא אמר עד מאה דולר ויש שמה במאה דולר את האוזניות האלה שאי אפשר להגיד שהם לא טובות ואיפה יש מחיר יותר נמוך מזה בניו יורק?
ה280 הם טובות יותר מהPC150\160 והICEMAT?
לדעתי כן ואני חושב שאתה תסכים איתי(אחרי הכל כל זה עניין סובייקטיבי)
אפשר להשיג 280 ב100$? O_O
איפה?
ו*אל* תקנה headset, תקנה אוזניות איכותיות והדסט פשוט בשביל המיקרופון או מיקרופון שולחני נפרד.
אם אתה לא הולך ללאנים בכלל תקנה מיקרופון שולחני, אם כן תקנה הדסט פשוט ושים סביב הצוואר (ואת האוזניות על האוזניים)
במחיר כזה יש לך אפשרות ללכת גם על ה-GRADO SR60 או SR80. אני לא יודע איך ה-60 ביחס לסנהייזר 280P אבל אני יודע
שה-80 בהחלט אוזניות טובות שרבים משבחים.
עריכה: אופס לא שמתי לב שאתה מדבר לצורכי גיימניג, אז אולי הסנהייזר מעט עדיפות במקרה זה, או שאם ההורים שלך היו מרשים לך להזמין מחו"ל
הייתי ממליץ לך על ה-AUDIO-TECHNICA אבל איך שהבנתי שזה לא ממש אפשרי...
האודיוטכניקה לא יהיו טובים במשחקים והגארדו יותר טובים מהסנסהייזר רק בבאס אבל בשאר הסקאלה הסנסהייזר עולות עליהם
280 במאה דולר :D
יש מה לבקש מאנשים לקנות בחו''ל!
תודה רבה על הקישורים
איפה?
לא ממש הבנתי מה אתה אומר בקשר למיקרופון =\
וכן אני הולך ללאנים ואני לא רוצה לקנות מיקרופון שולחני כי זה לא יהיה לי נוח =\
הדבר היחידי שעכשיו מרתיע אותי מלקנות את ה280 הוא שהאוזניות הללו הם למוזיקה בעיקרון ויש אוזניות אחרות שקצת יותר זולות או באותו מחיר שנועדו במיוחד למשחקים שזה בעיקר הבקשה שלי =\
אלה אם כן גם ה280 נועדו בשביל משחקים.
תודה.
הם לא נועדו במיוחד למשחקים אבל מה שטוב בהם שהם טובות בכל הסקאלה ואין איתם שום בעיה של המיד או הבאס מה לפעמים יש באזניות רק למשחקים
