need help! hebrew gybrish!
suddenly out of the bloom my windows xp stopped supporting the hebrew languge, giving me strange and gybrish like symbols...(ד??????)
i tried to unload and load again the support in the windows disc and tried to fix the windows instalation
the strange thing is that in word documents the hebrew is just fine
nedd your advice
thanx
You can try to this one open star control panel Language Int the language Tivhar Hebrew To disc in the
CD-ROM..... and ok and setup language hebrew support!///
nope...try that already even tried to reinstall the language from the cd nothing happens
what most frustrating is that it happened out of no where one menute evrything is ok and the next, havoc in the languge
Please Make Format And install The windows Again, In the install Press Hebrew in the languages
my friend, i know that format will do the trick and i m looking at it as the last resuort, and in the meantime trying to get other "friendly to the enviroment" solution ;)
טוב חברה פתרתי את הבעיה כל מה שהייתי צריך זה לעדכן את הווינדווס
תודה בכל מקרה
