חוות דעת למחשב חדש ב-6000 ש"ח
[16:46:31] [eSr^Rampage|ins] (16:44:27) (eSr^Rampage|ins) ?AMD? Price Units Total
[16:46:31] [eSr^Rampage|ins] (16:44:29) (eSr^Rampage|ins) Athlon64 3200+ (S-939) VENICE CORE 1230 1 1230
[16:46:31] [eSr^Rampage|ins] (16:44:30) (eSr^Rampage|ins) לוחות אם למעבדי ?AMD? GIGABYTE Price Units Total
[16:46:31] [eSr^Rampage|ins] (16:44:32) (eSr^Rampage|ins) K8NF-9 (NF4, s939, PCI-E) 610 1 610
[16:46:31] [eSr^Rampage|ins] (16:44:33) (eSr^Rampage|ins) זכרונות? DDR 400 Price Units Total
[16:46:31] [eSr^Rampage|ins] (16:44:35) (eSr^Rampage|ins) 512Mb 400MHz AData /VT 250 2 500
[16:46:31] [eSr^Rampage|ins] (16:44:36) (eSr^Rampage|ins) כרטיסי מסך? PINE Price Units Total
[16:46:31] [eSr^Rampage|ins] (16:44:38) (eSr^Rampage|ins) xfx 6800GT 256MB DVI,TV DDR3,PCI-E 2290 1 2290
[16:46:31] [eSr^Rampage|ins] (16:44:39) (eSr^Rampage|ins) דיסקים קשיחים? WESTERN DIGITAL Price Units Total
[16:46:31] [eSr^Rampage|ins] (16:44:41) (eSr^Rampage|ins) 160GB SATA 7200 8MB WD1600JD 505 1 505
[16:46:31] [eSr^Rampage|ins] (16:44:42) (eSr^Rampage|ins) כוננים- ??1.44, CD-ROM, DVD?? FLOPPY Price Units Total
[16:46:31] [eSr^Rampage|ins] (16:44:44) (eSr^Rampage|ins) Teac/SONY 1.44 40 1 40
[16:46:32] [eSr^Rampage|ins] (16:44:45) (eSr^Rampage|ins) כוננים- ??1.44, CD-ROM, DVD?? CD-ROM Price Units Total
[16:46:32] [eSr^Rampage|ins] (16:44:47) (eSr^Rampage|ins) LG x52 85 1 85
[16:46:32] [eSr^Rampage|ins] (16:44:48) (eSr^Rampage|ins) שונות ( מאווררים, מארזים נשלפים וכו'... )?? Fans Price Units Total
[16:46:32] [eSr^Rampage|ins] (16:44:50) (eSr^Rampage|ins) Thermaltake CAT 8cm 50 1 50
[16:46:32] [eSr^Rampage|ins] (16:44:51) (eSr^Rampage|ins) Thermaltake Volcano Silent Bost 150 1 150
[16:46:32] [eSr^Rampage|ins] (16:44:53) (eSr^Rampage|ins) מארזים? Price Units Total
[16:46:32] [eSr^Rampage|ins] (16:44:54) (eSr^Rampage|ins) HEC Compucase CI-6919 400W 410 1 410
[16:46:32] [eSr^Rampage|ins] (16:44:56) (eSr^Rampage|ins) מארזים? Power Supply Price Units Total
[16:46:32] [eSr^Rampage|ins] (16:44:57) (eSr^Rampage|ins) HEC 475W (True Watts) 360 1 360
[16:46:32] [eSr^Rampage|ins] (16:44:59) (eSr^Rampage|ins) Total price 6230 ¤
[16:46:35] [eSr^Rampage|ins] הספק
[16:46:38] [eSr^Rampage|ins] שהוספתי
[16:46:40] [eSr^Rampage|ins] שעולה 360 שקל
[16:46:41] [eSr^Rampage|ins] ב KSP
[16:46:43] [eSr^Rampage|ins] אתה צריך
[16:46:43] [eSr^Rampage|ins] לברר
[16:46:45] [eSr^Rampage|ins] איזה ספק
[16:46:48] [eSr^Rampage|ins] בא עם המארז
[16:46:53] [eSr^Rampage|ins] אם זה חרא ספק
[16:46:56] [eSr^Rampage|ins] תקנה את הספק
[16:46:58] [eSr^Rampage|ins] ב 360 שקל.
אם אתם יודעים איזה ספק בא עם המאוורר תרשמו פה:o
אני לא מצליח להבין כלום...
בצורה ברורה יותר...
LG x52 85 1 85
Total price 6230 ¤
המחשב טוב אבל יש כמה שינויים...
אתה יכול לקחת X800XL ולחסוך איזה 100-200 ש"ח עם אותם ביצועים בערך (בלי OC זה בעצם 2-3% הפרש ביצועים)
מעבד מצויין (כמו שאני שואל בהרבה מקומות בפורום... 3000 יספיק ?)
זכרון טוב (לא לOC)
לוח אם טוב
HD טוב (אני אישית מעדיף סיגייט אבל במחיר הזה יש רק 120GB שלהם מבחינת ביצועים במשחקים הוא יותר טוב)
כונן רגיל ? מילא DVD ובכלל כדאי לקנות צורב DVD ב300 ש"ח NEC ND-3540A
למה מאוורר 80MM ?
למה כזה קירור למעבד :nono: ?
הספק שבא עם המארז הוא HEC 400W ART אני חושב
ועדיף לקנות ספק של ENERMAX 350W במחיר הזה... למרות שהוא "רק" 350W הוא הרבה יותר חזק ועולה אותו דבר (ושקט יותר)
אוקיי אז ככה:
אין הבדל מחירים רציני בין 6800GT ל X800XL בחנות שממנה נלקח המפרט
המפרט עצמו בסדר גמור
אבל כמה תיקונים קטנים:
* מעבד אפשר לרדת ל 3000 ולא 3200 Venice
* לא צריך את ה Themaltake Cat 8cm
* לא צריך את ה Thermaltake Volcano SilentBoost
* לא צריך את הספק כוח הנוסף
זה חוסך 980 שקל
ובכסף הזה מוסיפים Nec 3540 צורב DVD שעולה 300
קיבלת את אותו מפרט וחסכת 680 שקל כמו כלום בלי להוריד מהביצועים
Dragonk
הספק כוח שבא עם המארז הזה הוא Hec 400W L-TD
ואין Enermax ב KSP (החנות שממנה לקחו את המפרט)
הייתי קרוב :silly:
אז זה מה שתיקח:
מעבדי ?AMD? Price Units Total
Athlon64 3000+ (S-939) 810 1 810
צורבים? DVD Recorders Price Units Total
NEC 3540A DVD±RW x16 Dual x8 300 1 300
HEC Compucase CI-6A21 400W 350 1 350
Total price + system assemly 5595 ¤
for payments 12 X 509 ¤
הרכבה כלולה. :)
התקציב הוא 6K אולי כדי להוסיף NF4 Ultra
במקום NF4 רגיל.
שיהיה כבר מוכן לעתיד עם תמיכה ב NCQ
firewire יותר מהיר
כל מיני הגנות שיש בחומרה
המפרט של Evman007 +
יש ב KSP את ה MSI NEO4 platinum
:xyxthumbs:
אם לוקחים את הלוח של MSI אז יש להחליף את הדיסק קשיח ל MAXTOR DIAMOND MAX 10 SATA NCQ.
נכון, מה שליאור אמר בתחילת הת'רד חשוב ונכון!
הלוח הזה MSI NEO4 platinum שאינו ultra, תומך בNCQ?
וכונן מקסטור diemond10 יותר טוב או פחות טוב מseagate תומך NCQ? (בביצועים במשחקים לדוגמא וכו')
הלוח מבוסס על צ'יפסט NFORCE 4 ULTRA,ויש לו תמיכה ב NCQ.
לגבי הכונן ,שניהם כוננים מצויינים ,קח את הזול יותר מהחנות שתקנה.
אז מה יותר טוב?
ה k8n-9 nforce 4 ultra של ג'יגה בייט או הMSI שדיברנו עליו?
ה MSi K8N Neo4 Platinum יותר טוב
