צריך עזרה במשחק מאפיה...
אני בשלב שאני צריך לפרוץ לאיזה בית ואיתי פורץ כספות...
השאלה היא איפה הכספת? איך מגיעים אליה?
google-> search: "mafia walkthorugh"->
http://www.cheatchannel.com/files/mafiafaq2.htm -> "visiting rich people"
Visiting Rich People
Salieri wants Tommy to go to the Prosecutor's house and steal the evidence that
is discriminating against him. Tommy has to take Salvatore (the best at
cracking safes).
-go to Vincenzo to get a bat & a Colt 1911.
-drive any of your cars to pick up Salvatore.
-go to Oak Hill.
-stop the car near the back door (Just by the road).
-ask Salvatore to lockpick the door & go in.
Once Tommy & Salvatore get in..........
-run to the statue on your left & crouch at the left hand side of that statue
(Salvatore will follow suit).
-order Salvatore to stay there.
Note: do not stand up!!!
-whip out your bat and wait for the guard to move past (coming in from the
right if you face the path).
-once the guard has stopped, go behind him and let him have the bat.
-take the key and the pump-action shotgun.
-move to where the guard came from. Ignore the 2 guards at the fountain as they
will not notice you unless you move too close. Head across the center path of
trees to the right of the garden.
-drop the shotgun before sneaking into the pavilion through the only entrance &
bat the guard out. Take the shotgun and go back to where you dropped your
shotgun.
-move near to the mansion and you will see a guard patrolling by the pool. Take
him out too after you have changed your shotgun for the bat. Take the shotgun
and pickup the previous shotgun. Now you have 8/32 shots in your shotgun.
Note: you will notice that the lights in the mansion will be on by time to
time. That's because the maid is doing her rounds.
-go back and get Salvatore.
-move towards the mansion by taking the western side of the garden. Once you
reach the 2 guards by the fountain, move behind the hedges around them. They
will not notice.
Note: those 2 guards will start talking to each other.
-head to the north side of the mansion and go through the side door there. Do
not wander too far to the front of the mansion as there are 2 guards there.
-go up the stairs all the way to reach 2nd floor.
-turn right then left and go through that door.
Note: if you want to bat some bitch, go through the first door on your right.
The woman by the dresser will call you 'darling'.
-move across the corridor crouch as the guard just patrolling in front of the
building will see you if you are standing.
-open the door in front and head left and go through the door. The safe is
here.
After the cutscene..................
-take the documents from the safe.
-head straight through the door ahead and down the stairs. Go through the door
at the right of the stairs. Go left into the kitchen and then into the dining
room. You may encounter the maid but leave her (poses no threat). Kill any
guards you encounter along the way. From the dining room, run back to the
starting point and exit the place taking out any guards you may meet.
Please be careful as Salvatore is nearby.
Note: -there are 5 guards left after you have follow the steps above.
-You can steal the car parked just outside with Salvatore
Skip the alternate way to the continue..... part if you choose this way.
מה קרה כולם נזכרו לשחק מאפיה פתאום?
חחח משימה יפה יש שם :)
חחחח בדוק...
זה ממש כיף לבוא לשומרים מאחורה לתת להם מכה אחת ולהרוג אותם....  :bash:
