problems with azureus, doesn't work
hy
i wanted to install azureus bitorrent downloading client but after i installed the azureus it told me that i need to install java too on my computer.
it gave me a link to download java. i download it and then when i wanted to use azureus it told me
"could not find the main class. progaram will exit"
what should i do to fix it????
after installing java, just re-install azureus.
its possible that you are missing the .jar file from the azureus directory, go to their site and download it separately
