פורסם 2005 בפברואר 2121 שנים ברשותי לוח גיגהבייט 8SQ800 ULTRA עם ביוס מעודכן כרטיס מסך ATI 9500PRO דריברים מעודכנים להיום 512mb memories hunday כרטיס קול וכרטיס רשת מובנה 2 כוננים קשיחים בסך כולל 160 מגה צורב תקליטורים LG WIN XP PRO SP2 מעודכן לפני כמה ימים <<< System Summary >>>-------------------------------------------------------------------------------- Warning 100: Large memory sizes should be made of Registered/Buffered memory.<<< Mainboard Information >>>-------------------------------------------------------------------------------- Warning 2533: Disabled host controllers are present. Check BIOS settings. Tip 2532: Consider adding more CPUs for better utilisation. Notice 224: SMBIOS/DMI information may be inaccurate. Tip 2511: Some memory slots are free so the memory can be easily upgraded. Warning 100: Large memory sizes should be made of Registered/Buffered memory. Warning 2540: No APIC detected for MP system. Tip 2513: AGP Bus is unused or AGP card not fully AGP compatible. Tip 2525: Current AGP data rate not optimal.<<< CPU & BIOS Information >>>-------------------------------------------------------------------------------- Warning 2533: Processor 1 : Disabled host controllers are present. Check BIOS settings. Tip 210: Processor 1 : Mainboard supports faster CPUs, so the CPU can be upgraded when needed. Notice 224: Processor 1 : SMBIOS/DMI information may be inaccurate. Notice 224: System BIOS : SMBIOS/DMI information may be inaccurate. Tip 212: System BIOS : BIOS can be shadowed so check whether it is. Tip 211: System BIOS : BIOS is flash-able and socketed so it can be upgraded when needed.<<< APM & ACPI Information >>>-------------------------------------------------------------------------------- Notice 224: SMBIOS/DMI information may be inaccurate.<<< PCI(e), AGP, CardBus Bus(es) Information >>>-------------------------------------------------------------------------------- Warning 1206: PCI Bus 0 (1/1x PCIClk) : Silicon Integrated Systems (SiS) SiS5513 EIDE Controller (A,B step) : PCI latency too high. Device could hog the bus for too long.<<< Video System Information >>>-------------------------------------------------------------------------------- Tip 323: Video Adapter : Primary Display Driver (display) : Remove the desktop wallpaper to save memory and improve performance. Tip 323: Video Adapter : RADEON 9500 PRO / 9700 (\\.\ DISPLAY1) @ \\.\DISPLAY1 : Remove the desktop wallpaper to save memory and improve performance.<<< Windows Memory Information >>>-------------------------------------------------------------------------------- Warning 2002: Memory load is 95% or more. Close down some applications.<<< Drives Information >>>-------------------------------------------------------------------------------- Warning: 1.44MB 3.5" (A:) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted. Tip 1821: Hard Disk (C:) : Label (name) drive. Tip 1821: Hard Disk (E:) : Label (name) drive. Warning: CD-ROM/DVD (G:) : Cannot obtain drive information; check that a disk is in the drive and it is correctly formatted.<<< Windows Information >>>-------------------------------------------------------------------------------- Tip 1300: Enter your company name or "Home" instead of "Unknown". Warning 1316: This copy of Windows contains Product Activation Technology. Warning 1322: Hardware DEP is not supported by your CPU. Software DEP in use. Consider upgrading for complete security.<<< WinSock & Security Information >>>-------------------------------------------------------------------------------- Warning 504: Services & Routing : Server IP services (FTP, HTTP, etc) enabled, check this is required.<<< Processes Information >>>-------------------------------------------------------------------------------- Tip 1601: MS_WebcheckMonitor : Program consumes a large amount of memory.<<< Modules Information >>>--------------------------------------------------------------------------------<<< DirectX Information >>>-------------------------------------------------------------------------------- Error: Modem #0 Line Playback (emulated) (WaveOut 1) : DX-DS E8878000A<<< Services Information >>>-------------------------------------------------------------------------------- Tip 2130: Alerter : Service may be disabled on Home/ Professional OS version. Tip 2130: Help and Support : Service may be disabled on Home/Professional OS version. Tip 2130: IPSEC Services : Service may be disabled on Home/Professional OS version. Tip 2130: Remote Registry : Service may be disabled on Home/Professional OS version. Tip 2130: Secondary Logon : Service may be disabled on Home/Professional OS version. Tip 2130: Windows Image Acquisition (WIA) : Service may be disabled on Home/Professional OS version. Tip 2130: Distributed Link Tracking Client : Service may be disabled on Home/Professional OS version.<<< ATA/ATAPI Information >>>-------------------------------------------------------------------------------- Warning 3100: ATA Controller 0 : ATA device (fixed) : SMART not enabled; consider enabling for safety. Warning 3101: ATA Controller 0 : ATA device (fixed) : Power management enabled. Consider disabling on desktops. Warning 3103: ATA Controller 0 : ATA device (fixed) : Acoustic Management enabled. Peformance may
פורסם 2005 בפברואר 2221 שנים רוב התוכנות האלה כוללות כלי לתיקון הבעיות.עם איזה תוכנה קיבלת את הדו"ח הזה?יש לך בכלל בעיות עם המחשב? כי מקריאה מהירה לא ראיתי איזה בעיה אמיתית.עריכה:למעשה מקריאה מהירה שניה נראה שהבעיה היחידה היא בכך שרוב הזיכרון של המחשב מנוצל, מה שיכול לגרום להאטה.נסה לסגור חלק מהתוכנות ולהריץ בדיקה של וירוסים וADWARE למיניהם.
פורסם 2005 בפברואר 2321 שנים הדו"ח הזה הוא מSANDRA כמובן. אני אתמצת לך את הדברים החשובים בו:1. PCI LATENCY גבוה מדי. תשנה את זה בBIOS.2. בזמן הבדיקה היה ניצול של 95% מהזכרון. אני לא זוכר שהבדיקה כל כך מפוצצת את הזכרון. בכל מקרה, תבדוק מה מצב הזכרון שלך כל הזמן עם FREERAMXP, או עם הTASK MANAGER.3. כל הSERVICES שהוא כתב לך שהם מיותרים, תבטל את העלייה שלהם דרך MSCONFIG > SERVICES.דרך אגב, אם אתה לא יודע מה אתה בדיוק עושה ולא בטוח, תעשה חיפוש כאן או בגוגל ואם אתה לא מוצא תשאל. בעקרון, כל השינויים האלה הפיכיים לחלוטין.
