פורסם 2005 בפברואר 1221 שנים מבין 3 הנגנים הבאים איזה מהם עדיף ? כל השלושה מציגים עברית אבל לMMV יש חיבור T.V OUT מפרט הMMV MMV II Include an 1.8 20GB hard disk drive. Support various memory card interfaces: CF, MicroDrive, SD, MMC, MS, MS PRO, SM, 2.0 LTPS TFT LCD provides crystal-clear images for direct viewing Users will be able view images, listen to music and watch movies from any of the memory cards or from the built-in HDD Users can copy data to and from any storage media, in any direction When connected to PC, MMV II acts as a USB 2.0 portable hard disk drive plus all-in-one card reader When connected to a NTSC/PAL TV, users will be able to view contents on TV screen and operate the MMV through infra-red remote control Support Rechargeable, user-swappable NP-120 battery for users convenience Support Multi-language filenames An optional USB 2.0 Host allows direct data transfer between MMV and other USB devices such as USB Flash Drives, USB-based CD-RW and printers. Features Built-in Storage 1.8'' HDD 20GB Up to 4 Primary Partitions Memory Card Support CF/MicroDrive SD/MMC/MS/MS Pro SmartMedia/xD JPEG Viewer Baseline Format Resolution up to 16M Pixels Zoom In/Out Rotate by 90 Shift Slideshow with Audio Motion JPEG Playback AVI & MOV File Format 352x240 @ 30 fps ADPCM Audio MPEG1 Playback DAT & MPG File Format 352x240 @ 30 fps MPEG1 Audio Layer II Audio Playback MP3 (MPEG1 Audio Layer I/II/III & 2.5) WMA 32Kbps ~ 320Kbps, CBR Support ID3 Tag Data Transfer Between Any Storage Media in Any Direction Copy, Paste, Delete and Other File Management Features Between PC and Any Storage Media File System FAT12/16/32 Video Display 2.0'' LTPS TFT LCD with Backlight Resolution 558 x 234 Pixels NTSC/PAL TV Output Internal Memory 2MB Flash 16MB SDRAM Output Source Composite Video/Earphone/Line Out Jack PC Connection USB 2.0 High Speed OS Supported Windows 98/98SE (with Driver) Windows ME Windows 2000 (SP3 and Above) Windows XP Linux Kernel Version 2.4 or Above Mac OS 8.6 ~ 9.0 (with Driver) Mac OS 10.0.1 and Above User Interface IR Remote Control OSD Menu Over 30+ Languages Support Hard Disk Working Conditions Operating: 0C ~ 70C Storage: -40C ~ 70C Humidity: 90% RH Dimensions (L x W x H) 126.5 x 70 x 23.5cm Weight: 230g מפרט הH320 Continuous Playback Time Approx. 16 Hours Connection Type Device: USB 2.0 Host: USB 1.1 (US model is not supported) Download Speed Device: Max. 480Mbps Host: Max. 12Mbps (US model is not supported) Equalizer 5 Preset EQ(Normal, Rock, Jazz, Classic, Ultra Bass) & 1 User EQ, SRS WOW Dimensions H320: 103 x 62.1 x 22.5 mm H340: 103 x 62.1 x 25 mm Weight H320: 183g (Including Battery) H340: 203g (Including Battery) Operational Temperature -5°C ~ 40°C Direct Encoding MP3 Voice Recording Yes Line In Yes Line Out Yes Optical In No Audio Frequency Range 20Hz~20kHz Headphone Output Power 20mW® + 20mW(L) (16Ω) at Max. Volume 11.6mW® + 11.6mW(L) (32Ω) at Max. Volume Line Output Power 900mV(L) + 900mV®, (47KOhm) at Max. Volume S/N Ratio 90dB : A weighted Frequency Characteristics ± 2dB No. Channels Stereo (L+R) FM Tuner Frequency Range 87.5MHz ~ 108MHz (KR, US, EU) 76MHz ~ 108MHz (JP) Headphone Output Power 13.5mW® + 13.5mW(L) (16Ω) at Max. Volume 8.5mW® + 8.5mW(L) (32Ω) at Max. Volume Line Output Power 520mV S/N Ratio 50dB : A weighted Antenna Headphone / Earphone-Cord Antenna File support File Type MPEG 1/2/2.5 Layer 3, WMA, ASF, OGG Bit Rate MP3: 32Kbps ~ 320Kbps Tag ID3 V1 Tag, ID3 V2 2.0, ID3 V2 3.0 Image File Type JPEG, BMP Text File Type TXT Video Main Set Display 2.0" inch TFT-LCD Display, 220x176 Power Supply AC Adaptor DC 5.0V, 2.0A Battery Internal Rechargeable Li-polymer Battery External Battery Pack 4 x 1.5V AA Battery O/S Windows requirement Window 98SE/ME/2000/XP MAC requirement MAC OS 9.2.2 or higher / Mac OS X 10.1.4 or higher and CarbonLib 1.6 or higher מפרט הH10 Storage 5GB General Continuous Playback Time Approx. 12 Hours Connection Type Device: USB 2.0 Equalizer 30 Preset EQ & User EQ, SRS WOW Dimensions Approx. 95.5 x 54.6 x 15 mm Weight Approx. 96.2g Operational Temperature 0°C ~ 40°C Direct Encoding MP3 Voice Recording Yes FM Recording Yes Line In with Cradle only Line Out with Cradle only Audio Frequency Range 20Hz~20kHz Headphone Output Power 18mW® + 18mW(L) (16Ω) at Max. Volume Line Output Power 900mV(L) + 900mV®, (47KOhm) at Max. Volume S/N Ratio 90dB : A weighted Frequency Characteristics ± 3dB No. Channels Stereo (L+R) FM Tuner Frequency Range 87.5MHz ~ 108MHz (KR, US, EU) 76MHz ~ 108MHz (JP) Headphone Output Power 18mW® + 18mW(L) (16Ω) at Max. Volume S/N Ratio 60dB : A weighted Antenna Headphone / Earphone-Cord Antenna File support Audio File Type MPEG 1/2/2.5 Layer 3, MP3 VBR, WMA Bit Rate MP3: 32Kbps ~ 320Kbps Tag ID3 V1 Tag, ID3 V2 2.0, ID3 V2 3.0,ID3 V2 4.0 Image File Type JPEG (The Progressive JPG is not supported.) Text File Type TXT Video Main Set Display 1.5 inch TFT-LCD Power Supply AC Adaptor DC 5.0V, 2.0A Battery Detachable Rechargeable Lithum-ion Battery O/S Windows requirement Window 2000/XP
פורסם 2005 בפברואר 1321 שנים אתה מצפה שמישהו יקרא את זה אבל H300 נגן בן זונה ולדעתי עדיף על H10 כי יש לו עוד 15 GB וזהו אבל אם אתה לא שומע הרבה שירים אז H10
פורסם 2005 בפברואר 1321 שנים אין כזה דבר עדיף.. השאלה מה אתה מחפש בנגן... גודל, קלות שימוש, נפח, מסך צבעוני..... תגיד מה יותר חשוב...בכל מקרה, לגבי ה MMV הנגן יצא כבר בשנה שעברה, אבל לא נראה כי יותר מדי אתרים כתוב עליו משהו... נתונים טכניים אתה יכול לצטט עד מחר, אבל הם לא אומרים כלום לגבי המכשיר... אם כבר כדאי לחכות עד שיהיה ביקורות עליו...אחרי בירור קצר ביותר בגוגל, למכשיר הזה ל MMV יש בין 3 ל 6 שעות זמן פעולה, ובלי בטרייה מתחלפת, ככה שבשביל נגן נייד, הוא לא כלכך נייד...
