מפרט: נייד 64ביט
מה דעתכם על המפרט הבא?
לפי מה שבדקתיי הוא נותן לי זמן סוללה הארוך ביותר לקטגוריה (תחליף לשולחני, סידרת  AMD64)
*הנתונים המודגשים הם אלה שהייתי רוצה שתסבירו עליהם בקצרה.
Acer Ferrari 3400 LMi
Processor & Core Logic
Mobile AMD Athlon 64 3000+ (40W)
VIA Apollo K8T800
System Memory
512MB (2*256) DDR333 SDRAM,
[upgradeable to 2048 MB with dual soDIMM modules]
Storage
80GB ATA-100 hard disc
4-in-1 card reader supporting Secure Digital, SmartMedia, MultiMediaCard, and Memory Stick formats
Internal DVD drive:
Read: 4x DVD+R, 4x DVD+RW, 4x DVD-R, 4x DVD-RW, 8x DVD-ROM, 24x CD-ROM
Write: 2.4x DVD+R, 2.4x DVD+RW, 2x DVD-R, 2x DVD-RW, 16x CD-R, 10x CD-RW
Display & Graphics
15.0" SXGA+ TFT LCD with 1400 x 1050 pixel resolution, 16.7 million colours, 185 nit high brightness
ATI® Mobility Radeon® 9700 with dedicated 128MB of video memory
8× AGP graphic accelerator
MPEG-2/DVD hardware assisted capability
DualView support
External display resolution up to 2048 x 1536, 75Hz, via non-interlaced CRT display
Simultaneous LCD and CRT display at 1280 x 1024 pixel resolution, 16.7 million colours, 75Hz
Dimensions & Weight
330 (W) x 272 (D) x 31 (H) mm
2.93kg* for 15.0 LCD model
(*actual weight may differ, depending on configuration)
Networking & Communication
Integrated 10/100Mbps Fast Ethernet
Integrated 56K V.92 data/fax software modem (with international PTT approval)
Wireless LAN: Acer InviLink IEEE 802.11g
Wireless PAN: Integrated Bluetooth
I/O Ports
4 × USB 2.0 ports
1 × IEEE 1394 port
1 × S-video-out (NTSC/PAL) port
1 × FIR port
1 × ECP/EPP-compliant parallel port
1 × RJ-11 jack for modem
1 × RJ-45 jack for Ethernet
1 × external VGA port
1 × speaker/ headphone/ line-out jack
1 × microphone/ line-in jack
1 × CardBus type II slot
1 × DC-in jack for AC adapter
Power Subsystem
ACPI power management standard supports Standby and Hibernation power saving modes
3-pin 90W AC adapter
8-cell Li-Ion battery pack
3 hours battery life (actual battery life might vary, depending on usage and configuration);
4.5 hours charge-in-use
Quality & Reliability
Tests Temperature & Humidity Test
Acoustics Test
Electrostatic Discharge Test
Hinge Life Test
Free Drop Test
Weight Pressure Tests
Spill Test
Shock and Vibration Test
MTBF (Mean Time Between Failure) Test
Operating System
Microsoft® Windows® XP Home Edition
Software
BIOS User and Administrator passwords
Acer Launch Manager
Acer System Recovery CD
Norton AntiVirus (Trial Version)
Adobe® Acrobat® Reader®
CyberLink® PowerDVD®
NTI® CD Maker
Options
Additional 3-pin 90 W AC adapter
Additional Li-ion battery pack
Memory expansion modules
System Compliances
ACPI 1.0b
Warranty
1 year International Travellers Warranty
אני יודע. המחירים הרבה יותר אטרקטיביים בארה"ב, אפילו עד מחצית מהסכום בארץ (ללא משלוח ןמ.ע.מ)
ה40W של המעבד זה צריכת חשמל
K8T800 זה הצ'יפסט של VIA
שתי השורות בתיאור של המסך זה לגבי היציאות שלו למסך חיצוני, מה שהוא מסוגל לשדר אליו
OK עכשיו אני יודע. תודה.
VIA זה השם של לוח האם אם כך? ומה אתה יכול להגיד על הצ'יפסט (ולדרג אותו לאחרים)?
40W צריכת חשמל במעבד בנייד? :smile1: אתה יודע שהמחשב הזה מסוגל גג גג להחזיק שעתיים וחצי של עבודה חזקה..בלי חשמל..ובמקרה הגרוע אולי שעה וחצי.
ולא רק ביגלל המעבד..אלא גם ביגלל כרטיס המסך ועוד..
לא רואה שימוש חכם בנייד כזה אבל השם פאררי מוסיף יוקרה בהתאם גם מוסיף אלפי חי שקלים למחיר.. ;D
VIA זה היצרנית של הצ'יפסט
לA64 יש שתי יצרניות צ'יפסטים עיקריות - NVIDIA ו-VIA (גם SIS מייצרת, היא פחות נפוצה, וATI נכנסה לשוק לא מזמן), ההבדלים ביניהן באים לביטוי בעיקר במחשבים שולחניים, לא בניידים, לא נראה לי שזה משנה פה
אני לא יודע למה זה מפתיע אותך. ניידים אחרים בקטגוריה מחזיקים אפילו פחות זמן. ה-A64 כאן לפחות ייעודי למטרות ניידות ומשתמש ב-HyperTransport, בצירוף עם יכולות החיסכון בחשמל של ווינדוס..זה הכי שאפשר לבקש.
סנטרינו ייתן תמיד זמן סוללה ארוך יותר מאחרים אבל אני לא מעוניין בנייד סנטרינו אלא ב-64 ביט.
ידוע לך שהדותן נותן הרבה יותר ולוקח הרבה פחות מהמפרט שנתת פה ?
הדותן אני מאמין אפילו יעבור אותו אם לא הוא יעמוד על אותם ביצועים כמו ה 64ביט הנ"ל.
יכלת לתת לי השוואה עוד יותר טובה עם דגם A64 מקביל הזהה אליו במפרט.
בכל מקרה ניידים עם מעבד זהה וראדון 9700 128M מגיעים היום עם מסכי 15.4 ועולים בסביבות 7-8. בחו"ל אפשר למצוא את הנייד הזה במחירים האלה (תתפלא אבל זה כך, חצי מחיר מפה ופחות מזה).
עולם המחשבים, כמו שאר המוצרים הנמכרים בעולמינו, גם הוא אינו רק תוכו כברו, ושם החברה, יוקרה ואופנה הולכים איתו גם כן. זה בערך כמו שתגיד לי שגם גופייה בשוק עשוייה מ-100% כותנה, כמו חולצה של פוקס, רפליי או דולצ'ה וגבנה...
בכל מקרה 40W היא צריכת חשמל נמוכה, לפי כל ההגדרות ובאשר להשוואה עם בניאס...נכון, סביר להניח שהוא ימשיך לפעול על יישומי אופיס ואינטרנט אחרי שזה כבר יכבה לי ואצטרך להטעין, אבל אם נריץ על שניהם סרט,..שניהם יכבו לפני מחציתו (כעבור שעה). אפשר לראות זאת יפה בהשוואה שנעשתה בטומ'ס בין סנטרינו ל- M A64:
http://www6.tomshardware.com/mobile/20030507
תמצא שם שההצהרות של אינטל נושפות בעצים גבוהים מידי,..
