ביקורות על ה CREATIVE ZEN MICRO
DESIGN TECHNICA נתנו ציון די נמוך של 6 מתוך 10:
Highs: Excellent sound quality; more features than comparably priced models
Lows: Prone to locking up; uncomfortable ear buds; poor battery life; slow transfer speeds
There is a reason why the iPod reigns supreme; it simply works as it says it will. Apple has made us upset with their unwillingness to support software other than iTunes and we were really hoping the Creative Labs Zen Micro would be a good alternative, but it just left us feeling let down. If you read any other reviews both in print publication and on the web, you will be led to believe that the Zen Micro is the iPod killer we have all been waiting for, but it isn't. We have to wonder if these other publications even tested the Zen Micro before writing a review. After testing two different players and using them for a couple months, the flaws in the Zen Micro were very obvious to us.
Creative Labs has a couple problems they need to address before they can stand to compete with others in this market. First of all, something is draining the battery life from its player at increased rates, both when it's being used and when itâs powered off. Getting four hours of battery life from a 12-hour battery is inexcusable. Secondly, while we love the audio quality from their ear buds, they are too big to use for long periods and will make your ears very sore. Lastly, Creative needs to polish their own MediaSource software and work on software compatibility with other Media Players like RealPlayer and MusicMatch. Here is our suggestion for Creative Labs: make a hard drive based digital audio player with only a few polished features and make sure it works well. Throwing in everything but the kitchen sink shouldnât automatically mean itâs the best, it has to work correctly first.
http://reviews.designtechnica.com/review2180.html
ביקורת קצת קשה...
במיוחד כי הרבה אחרים אמרו אחרת:
CNET נתנו 8.7 מתוך 10, כולל EDITORS CHOICE
http://reviews.cnet.com/Creative_Zen_Micro_5GB_black/4505-6490_7-31151919-2.html?tag=top
http://www.monsternet.org/features/crzenmicro/page8.php
9 מתוך 10
http://www.hardwarezone.com/articles/view.php?cid=9&id=1322
4.5 מתוך 5...
סתם אתר.. בטח APPLE שילמו להם בוחטה כדי לחרטט את הנגן.
הייתי בטוח שהאתר קשור ל ARS TECHNICA (אתר די טוב), אבל זה לא רשום באף מקום... למרות שהעיצוב נראה דומה...
בכל מקרה, יש שם את ה USER REVIEWS ששם הוא קיבל ציונים יותר טובים
http://reviews.designtechnica.com/user_reviews2180.html
