hi from australia... about IRIVER PRICES pls help
hi all.. i m asking about IRIVER H340...
$i found it here under the price tag of 750
(681$ after the 10% discount)
so its something like 2225 shekels
u know if i can find it cheaper?
israel my-b thailand?
thanks Jacob
I think you should buy a different player. One that doesnt look like an eraser of a school board
:s07:
well
i guess you know the prices here with arcadia
if you dont
iriver.arcadia.co.il
its alot more expencive then 2250
but cant you find it cheaper is australia
אוקי אני משער שהמחשב שאתה משתמש בו יכול להציג עברית..
אני חושב שאתה יכול למצוא את המכשיר בפחות כסף באוסטרליה תמשיך לחפש =)
הא ועוד משהו,
אני יודע שזה לא נהוג אבל בכל זאת שמעתי שהמחירים באוסטרליה ממש זולים ורציתי לדעת אם יש איזשהו סיכוי שאני יעביר כרגע למישהו מהמשפחה שלך שנמצא בארץ כסף ותוכל לקנות לי שם =\ ? אני יודע שזה קצת הזוי אבל שמעתי שזה עולה שם בסביבות ה1000-1200 שקל אני מדבר על הH320
you can allso try asking in mysticriver.net
thay have some people from australia so am sure thay can try to tell you...
Hi all and thanks for your advice...
and yes i can c hebrew :)
well i found it a bit more cheaper in other store.. in sydney... and its cost me
640$
and when i m taking the 10% off i on
576$
wich is aprox 1900 shekel :)
so i think its cheap enough...
and i m sory m8 i will love to buy u 1.. but i m leaving in 2days.. and its weekend and as u know they dont work on
sat and sunday.
but i have the name.. and i think .. not sure u can order online... i didnt check it
shit i dont have the address on me..
(i  m in internet cofe shop)
Thanks alot and i'll update in few days... :)
hi all
now from New Zealand :)
i got the site address its
http://www.ccccamerahouse.com.au
well i did a quick search for the h340 and couldnt find it. and i dont think they do oversea
but
it worth a shot to give them a call and tell u know of some1 who bought it
and if they do the oversea
anyway
good luck
and bye
