ICMP (ping) check
1. Your Tweakable Settings:
Receive Window (RWIN):  37752
Window Scaling:  0
Path MTU Discovery:  ON
RFC1323 Window Scaling:  ON
RFC1323 Time Stamping:  ON
Selective Acks:  ON
MSS requested:  1452
TTL:
(less any hops behind firewall)
62
TTL remaining:  47
2. Test 146000 byte download
Actual data bytes sent: 146000
Actual data packets: 101
Max packet sent (MTU): 1492
Max packet recd (MTU): 1492
Retransmitted data packets: 0
sacks you sent: 2
pushed data pkts: 8
data transmit time: 3.226 secs
our max idletime: 503.8 ms
transfer rate: 29764 bytes/sec
transfer rate: 238 kbits/sec
This is not a speed test!
transfer efficiency: 100%
3. ICMP (ping) check
Minimum ping: 403 ms
Maximum ping: 417 ms
Ping stability:
416 417 409 407 403 408 403 408 407 407
USA based? - ping is high
מחובר:  בזק בן לאומי ADSL 1500
מודם: ALCATEL HOME PPPoE
ראוטר: EDIMAX
איך גורמים ל PING להיות יותר נמוך
