איך המסך הזה? Dell D1626HT Trinitron "21 שווה השקע או לא??.
הנה המפרט שלו:
http://www.ktl.co.il/UploadProductFiles/מפרט%20טכני%20מפורט.doc
המסך בעיקר למשחקים וסרטים..!!..
מי שלא יכול לקרוא או משהו כזה..
repasovaný monitor
Dell D1626HT Trinitron 21" Color Monitor  Specifications
General
Model number D1626HT
Marketing series name UltraScan 1600HS Series
Part number 55347 (North American)
NOTES: Damper wires are visible on Trinitron monitor displays. You may notice one or more fine horizontal lines on your monitor display, particularly on screens with white backgrounds. Larger monitors have two lines; smaller monitors have one line in the bottom third of the screen. These lines are normal and part of the monitor technology.
The damper wires are used to stabilize the vertically striped aperture grill. This aperture grill design allows more light to pass through to the screen, giving the Trinitron CRT more vibrant color and brightness.
Input Signals
Video analog, 0.7 Vpp, positive at 75 ohm
Separate sync TTL level, positive
Composite sync TTL level, polarity free
Sync on green 0.3 Vpp +/- 10%, negative
Scanning Frequency
Horizontal 107 kHz
Vertical 48 to 160 Hz
CRT
Screen dimensions 21 inches
Diagonal viewable image size 19.8 inches
CRT deflection angle 90°
Aperture grill pitch 0.25 mm (center) - 0.27 mm (corner)
Phosphor type P22 (medium short persistence)
Faceplate coating sputter
Display area 388 mm x 291 mm
Physical Characteristics
Connector 15-pin D-subminiature
Signal cable type detachable
Dimensions: Height 504 mm (20 inches)
Width 498 mm (19.625 inches)
Depth 474 mm (18.875 inches)
Weight 31 kg (68 lb 5 oz)
Power
Energy Star compliant yes
Power consumption: Normal operation <160 W (maximum)
Standby mode <100 W (maximum)
Suspend mode <15 W (maximum)
Active-off mode <5 W (maximum)
AC input voltage/frequency/current 100 to 120 VAC, 50/60 Hz, 2.0 A;
220 to 240 VAC, 50/60 Hz, 1.0 A
Inrush current 120 VAC/50 A;
240 VAC/80 A
Steady state current 2 A to 1 A
Environmental
Temperature: Operating 10° to 40°C (50° to 104°F)
Nonoperating 0° to 60°C (32° to 140°F)
Humidity: Operating 10% to 80% (noncondensing)
Nonoperating 5% to 90% (noncondensing)
Altitude (operating) 03048 m (010,000 ft)
Thermal dissipation 410 BTU/hour (normal)
Resolution
Maximum horizontal 1600 pixels*
Maximum vertical 1200 lines*
* The highest preset resolution supported is 1600 x 1200 at 85Hz.
Video Presets/Frequencies
Modes Resolution Horizontal Vertical
1 640 x 480 31.5 kHz 60 Hz
2 640 x 480 37.5 kHz 75 Hz
3 640 x 480 43.3 kHz 85 Hz
4 720 x 400 31.5 kHz 70 Hz
5 720 x 400 37.9 kHz 85 Hz
6 800 x 600 37.9 kHz 60 Hz
7 800 x 600 46.9 kHz 75 Hz
8 800 x 600 53.7 kHz 85 Hz
9 1024 x 768 48.4 kHz 60 Hz
10 1024 x 768 56.5 kHz 70 Hz
11 1024 x 768 60.0 kHz 75 Hz
12 1024 x 768 68.7 kHz 85 Hz
13 1152 x 864 67.5 kHz 75 Hz
14 1280 x 960 60.0 kHz 60 Hz
15 1280 x 960 85.9 kHz 85 Hz
16 1280 x 1024 64.0 kHz 60 Hz
17 1280 x 1024 80.0 kHz 75 Hz
18 1280 x 1024 91.2 kHz 85 Hz
19 1600 x 1200 75.0 kHz 60 Hz
20 1600 x 1200 81.3 kHz 65 Hz
21 1600 x 1200 87.5 kHz 70 Hz
22 1600 x 1200 93.8 kHz 75 Hz
23 1600 x 1200 106.3 kHz 85 Hz
Regulatory
Safety Certifications: CSA labeled
EN 55022 Compliant
UL listed
MPR
VLF
ELF
MPRII
TCO-95
NOM license (Mexico)
EMC Certifications: FCC Class A
FCC Class B
European-Specific: NEMKO, SEMKO, DEMKO, FIMKO
CE-Mark
TUV-GS
ISO 9241-3
תודה ירון
יש אשכול עליו כבר.
בעקרון זה מסך סביר, אבל מיושן, יש לו משהו כמו 5 שנים טובות.
השפורפרת שלו איכותית, אבל מיושנת 1600*1200 למסך 21" זאת רזולציה דיי גבולית, ואתה תצתרך כרטיס מסך עצבני כדי לשחק משחקים על רז' כזאת.
