audio driver instellation and regional and language settings
i just did a format and i need to instell the audio driver, the thing is i downloaded the driver but its just files and i dont have an idea where to put the files the audio driver is SIS7012
heres the second problam , i want to change the settings to hebrew but the thing is there is no option of hebrew , i mean i can set the regional setting to isreal but i cant configure it to hebrew cuz it just isnt there O_o
first problem - right click "my computer" and click "properties" goto hardware>>device manager
you should see a "multimedia audio device" with a yellow icon ,right click it and click "update driver" select the 2nd option and click "next" uncheck the box "search removable media (floppy.cdrom)" make sure "include this location in the search" is checked and click "browse" pick the folder where you unzipped the driver and click "ok" click "next"
second problem - click here
יש לי בעיה דומה - הורדתי דרייבר - ייתכן שהוא הדרייבר הלא נכון? איך אני בודק בדיוק איזה דרייבר יש לי
הורדתי מהאתר של אייסוס את הדרייבר המדוייק ללוח אם שלי...אני על סף זריקת המחשב מחוץ לחלון.
