שלום אני צריך בבקשה עזרה מתלבט בין שתי נגני Mp3
January 7, 2005 will be the release date in Korea with the rest of the world following
אני יודע אבל לפי מה שכתוב פה לא יקח הרבה זמן עד שזה יצא לשאר העולם אני מאמין שזה יקח שבוע שבועיים אלא עם כן יהיה עיקוב כלשהו
  • תגובות 35
  • צפיות 2.3k
אם אפשר בבקשה עוד פרטים על הנגן שהולך לצאת.. או לינק?
כמה gb? צבעוני? מחיר?
ממ בינתיים יש מידע רק על הH10  שעומד לצאת בקרוב
H10 = 5 GB
H20 = 20GB
FEATURES !
Aluminum Body = as small as name card
Headphone output: 18mw(16ohm max.)
Playback time: Approximately 12hours
(128kbps MP3,Normal EQ,VOLUME 20,LCDoff)
Detachable rechargeable Lithum Ion Battery
You can buy extra battery to extend the playback time
FM Tuner (can be used worldwide)
FM RADIO RECORDING (it can be started automatically at the time that user set)
FM STATION AUTO MEMORY
Etc.
260K colour 1.5" TFT LCD
Touch Scroll Interface
USB MASS STORAGE FUNCTION (external hard drive function, not USBOTG)
SRS WOW + 30EQ PRESETS+ USER EQ(not sure about how many bands we can change)
Iriver plus
-automatic synce function (similar to itunse's function)
-"GracenoteR Music ID" it can download information about music by internet.
Music files encoded by 'direct encoding' function can have music information
by using it.
WMA(DRM)
Windows Media Techonologies's DRM techonology is fully supported.
Napster+???(never heard of it before) music stores are supported.
※DRM files should be transferred by iriver plus
USB 2.0 interface
Image viewer+text viewer(works simutaneously with playing music)
Voice recording
IDS TAG DATABASE SERCHING FUNCTION
Similar to other player's features
Songs will be organized by artist, album, genre.
In order to use this funtion, you have to transfer your music files by iriver plus
Firmware Upgrade
Specification > HDD
> Capacity 5GB※
> File system FAT32
> PC
> OS Windows 2000/XP
> interface USB2.0
> Audio
> Frequency: 20Hz ~ 20KHz
> headphone output: 18mW(left) + 18mW(right)(16ohm)max.
> Signal to Noise ratio: 90dB (MP3)
> Frequenct Characteristics: ±3d B
> Channels stereo: L+R
> FM RADIO
> FM Frequency: 76.0MHz ~ 108MHz
> Signal to Noise ratio: 60dB
> Antenna: Headphone/Earphone-Cord Antenna
> File Format
> File Type: MP3(MPEG 1/2/2.5Layer3) ,WMA,TXT,JPG※※
> Bit rate MP3: 32kbps~320kbps
WMA: 32kbps~192kbps
> Tag: ID3 V1,ID3 V2 2.0,ID3 V2 3.0,ID3 V2 4.0
> Power
> AC Adapter DC 5.0V, 2.0A
> Battery: detachable+rechargeable battery
> General Specification
> Dimension: Approximately 95.5(height) x 54.6(width) x 15(depth) mm
> Wight: Approximately 96.2g
> LCD: 1.5" 260K COLOR  TFT LCD
> Operation Temperature -5℃~40℃
> Playback Time: Approximately 12시간(128Kbps,MP3,Volume:20,EQ:Nomal,LCD off)
※1GB = 1,000,000,000byte. Some parts of capacity are not usuable because they are used to store system information.)
※※Progressive JPG is not supported.
Package Contents
H10/Quick Start Guide/Manual/Earphone/AC Adapter/Case/USB CABLE/INSTALL CD/Warranty(1 year)
*IF you register in iriver homepage(japan) you can have extra 6 months of warranty.
>Cradle (cables are included)
>USB CABLE
>AUDIO CABLE
>Remote
>Extra Battery
Accesorry iriver e·store retail price
H10[5GB] Cradle(Black) \3,480 Yen ($33 USD)
H10[5GB] Battery(Neo Silver) \2,980 Yen ($29 USD)
H10[5GB] Battery(Deep Red) \2,980 Yen ($29 USD)
H10[5GB] Battery(Midnight Blue) \2,980 Yen ($29 USD)
H10[5GB] Battery(Slate Grey) \2,980 Yen ($29 USD)
H10[5GB] Remote(White Silver) \2,480 Yen ($24 USD)
H10[5GB] Remote(Ebonique Rocke?) \2,480 Yen ($24 USD)
מקור Mistic River ומידע נוסף
מצטער על ההודעה הארוכה אבל הנחתי שלא לכולם יש חשבון שMISTIC RIVER אז פשוט כדאי להעתיק את זה
פששש... מאוד מזכיר לי משהו... http://www.hwzone.co.il/community/index.php?topic=97525.0
קיצר.. המחיר כמובן זה לא המחיר בארה"ב (345$.. ממש מישהו יתקרב לזה).
אני אומר שלפני פברואר במקרה הטוב לא יראו את זה (לפי דעתי ה H3XX יצא בקוריאה והגיע לארה"ב כמה חודשים טובים, 4-5 אחרי...), הם עושים שינויים ל FIRMWARE, עושים עוד בדיקות, לפעמים משנים את החומרה (הורדת ה USB2GO וכו')...
כמו כן, ה H20 הרבה יותר רחוק ושוב, עד אז יהיו עוד דברים (IT NEVER STOPS :) ), לא בטוח שכדאי לחכות כל הזמן לדבר הבא.
מצטער כבר חודשיים לא הייתי בפורום ולא שמתי לב להודעתך :\
5 gb לא יספיקו לי =(
לא יודע אם לקנות את הH120 או לחכות קצת ולקנות את הH340 או לחכות לנגן טוב אחר שיצא..
