ATI CATALYST� 4.12 - שוחרר
תיקונים עיקריים בגרסא החדשה:
- Half-Life 2: Playing the game on a system containing an Athlon XP CPU no longer results in missing textures occationally being noticed
- Half-Life 2: Intermittent psychedelic patterns are no longer seen when playing the game under Windows XP
- CounterStrike: Playing the game under Windows XP with an ATI RADEON X800 series installed no longer results in display corruption being seen in the floor in de_chateau map
- Doom 3: Playing the game under Windows XP with an ATI RADEON X800 XT Platinum Edition no longer results in display corruption being seen when pressing CTRL+Alt+Delete followed by clicking Cancel
- Everquest: Playing the game under Windows XP with an ATI RADEON X800 XT Platinum Edition installed results in the game displaying a black screen when setting the texture quality to high and having all radio buttons selected
- Medal of Honor: Pacific Assault: Setting the model detail to high and change the game resolution to high no longer results in the game failing to respond under Windows XP with an ATI RADEON X800 series installed
- Tron2.0: Setting the display device resolution to 1280x1024 32bpp and setting the display option for the game to 800x600 32bpp no longer results in display corruption being seen in the game cinematics
- Star Wars Knights of the Old Republic: Playing the game under Windows XP with an ATI RADEON X800 series installed no longer results in triple buffering failing when enabling the option in the CATALYST CONTROL CENTER
Attempting to rotate the display 90 degrees and play an OpenGL game under Windows XP may result in the game failing to launch
Enabling clone mode along with theatre mode option under overlay no longer results in WinDVD and the operating system failing to respond when dragging the WinDVD window around the desktop
Display corruption is no longer noticed when playing a DVD using WinDVD and having subtitles enabled under Windows XP with an ATI RADEON X800 series installed
Attempting to make a change to a saved profile within the CATALYST CONTROL CENTER no longer results in the Save button being greyed out
Connecting a secondary CRT and clicking the X button to close the Enable this display window found in the CATALYST CONTROL CENTER Advanced view, no longer results in the window not closing
Muting the audio during the playback of full screen HDTV video under Windows Media Center Edition no longer results in the video being paused
Angle information in the rotation modes is now correct for the CATALYST CONTROL CENTER
Enabling Overscan under Windows XP with an ATI ALL-IN-WONDER 9600 installed no longer results in the image not being centered properly on the display device
Connecting a secondary CRT display device and extending the desktop, followed by unplugging the secondary device and hot-plugging a DFP device no longer results in the DFP remaining in the Additional display area when attempting to swap devices
The Windows desktop brightness no longer dims when playing a DVD and having an HDTV connected as the primary display device
Playing a DVD under Windows XP MCE with an ATI RADEON X800 XT installed no longer results in VPU Recover being activated when attempting to drag or resize the Media Center window
An error message is no longer displayed when attempting to switch a secondary display device back to the primary display device when using the CATALYST CONTROL CENTER
CATALYST Release Note Version 4.12
CATALYST 4.12
CATALYST 4.12 בתוספת CATALYST Control Center
OVERDRIVE Version 3.0
The latest release of CATALYST introduces OVERDRIVE version 3.0 for the RADEON X850 XT. This version of OVERDRIVE will allow users to manually set the graphic and memory clocks, while still protecting the user from causing damage to their graphic card. OVERDRIVE version 3.0 also provides an optional automated search for maximum clock speeds. This feature is supported under both the Windows XP and 2000 operating systems
יש לזה גם תמיכה בOC
יופי! נמאס לי כבר מאומגה הזה >:(
יש תבטא 4.12 של ATi לא חייבים אומגה, למרות שה4.12 שלהם מוצלח הפעם.
זה משפר משהו עם 9600XT?
אפשר להתקין הגרסה הזאת על הגרסה הקודמת בלי למחוק כלום ?
עדיף שתסיר מהוספה/הסרה, תעשה הפעלה מחדש למחשב ותתקין את זה
omega 4.12 beta :
AQ3 : 46,200
omega 4.10 beta :
AQ3 : 47,017
ראיתי את זה וכבר נבהלתי והחלפתי מהר ל4.10 הישן והטוב שלי... וזה עם אוברקלוק לכרטיס ל425\375 , אני גם מגיע במקסימום ל48\9 אפילו...(6600GT של חבר שלי מקבל עם מערכת מאוד דומה על וכרטיס על סטוק 47-48אלף... , ככה שיש עתיד :) )
אצלי היה שינוי לטובה
אם אפשר ליקרוא לזה שינוי :s07:
500 נק באקווה
3DMARK
01 300 נק
03 50 נק
05 נקודה ;D
ה OVERDRIVE זה לכל הכרטיסים?
כמו קודם רק לבעלי מד טמפ' מובנה
הם תיקנו את הבאג שגורם למשחקי רשת מסויימים לקרוס אחרי 2 דקות?
גם אצלי הדרייברים הישנים גרמו למשחקי רשת(ET) להעיף אותי מישהו יודע אם הבעיה נפתרה ?
אני חושב שזה רק לסדרות של ה XT
היה באג עם הפאנק באסטר, הוא סודר.
