האם זה מעבד BARTON 2600?
איך אני יודע אם המעבד שיש לי הוא באמת AMD 2600 Barton?
ניסיתי לבדוק עם SiSoftware Sandra אבל יש שם נתונים סותרים:
SiSoftware Sandra
Processor
Model : AMD Athlon
Speed : 1.14GHz
Model Number : 1416 (estimated)
Performance Rating : PR1659 (estimated)
Type : Standard
Package : Socket A PGA
Multiplier : 23/2x
Generation : G7
Name : Duron M10 & Athlon MP/XP (Barton/Thorton) 1.8GHz+ 1.65V
Revision/Stepping : A / 0 (0)
Stepping Mask : A2
Core Voltage Rating : 1.650V
Maximum Physical / Virtual Addressing : 34-bit / 32-bit
Co-Processor (FPU)
Type : Built-in
Processor Cache(s)
Internal Data Cache : 64kB Synchronous Write-Back (2-way, 64 byte line size)
Internal Instruction Cache : 64kB Synchronous Write-Back (2-way, 64 byte line size)
L2 On-board Cache : 512kB ECC Synchronous Write-Back (16-way, 64 byte line size)
L2 Cache Multiplier : 1/1x (1144MHz)
Upgradeability
Socket/Slot : Socket A
Upgrade Interface : ZIF Socket
Supported Speed(s) : 2.20GHz+
Environment Monitor 1
Model : Winbond W83627HF ISA
Version : 2.01
Mainboard Specific Support : No
Power Rating(s)
CPU Core Power : 37W (estimated)
CPU Cooling System Thermal Resistance : 0.28C/W (estimated)
Sensors
CPU Temperature : 43.5°C / 110.3°F
Auto Fan Speed Control : No
CPU Fan Speed : 3409rpm
CPU Voltage : 1.63V
Features
FPU - Co-Processor Built-in : Yes
VME - Virtual Mode Extensions : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
CX8 - Compare & Exchange Instruction : Yes
APIC - Local APIC Built-in : Yes
SEP - Fast System Call : Yes
MTRR - Memory Type Range Registers : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
CLF - Cache Line Flush Support : No
DS - Debug Trace & EMON Store : No
ACPI - Software Clock Control : No
MMX Technology : Yes
FXSR - Fast Float Save & Restore : Yes
SSE Technology : Yes
SSE2 Technology : No
SS - Self Snoop : No
HTT - Hyper-Threading Technology : No
TM - Thermal Monitor : No
SBF - Signal Break on FERR : No
SSE3 Technology : No
MON - Monitor/MWait : No
DSCPL - CPL qualified Debug Store : No
TM2 - Thermal Monitor 2 : No
EST - Enhanced SpeedStep Technology : No
CID - Context ID : No
DAZ - Denormals Are Zero : No
Extended Features
SYCR - Extended Fast System Call : Yes
EMMX - Extended MMX Technology : Yes
3DNow! Technology : Yes
Extended 3DNow! Technology : Yes
SMP - MP Capability : No
Power Management Features
VID - Voltage Control : No
FID - Frequency Control : No
TS - Thermal Sensor Built-in : Yes
Advanced Settings
TLB Cacheable : Yes
System Ack Limit : 8 request(s)
System Victim Limit : 0 request(s)
Extended MTRR Types : Yes
I/O Type Range Registers : Yes
Top of Memory : 20000000 (512MB)
Machine Check Architecture Settings
Number of Reporting Banks : 4 bank(s)
Exception Reporting Control Support : Yes
תבדוק עם cup-z
בדקתי:
זו מהירות היא של 2600?
תודה מראש
כן, רק שהוא עובד באנדרקלוק.
הוא אמור לעבוד על באס 166, והוא עובד על באס 100.
קניתי את המחשב לפני חצי שנה וככה הוא הגיע מהחנות (ששמעתי הרבה דעות לא טובות עליה אח"כ...),
זו לא ירידה משמעותית בביצועים?
זו ירידה דרטסית בביצועים.
איזה לוח אם יש לך? איזה זיכרון?
הנה הנתונים מ- cpuz:
כבר חצי שנה אני מפעיל תוכנות שדורשות הרבה כוח חישוב :s07:, ככה זה שקונים ממקום לא מקצועי :pissed:
תודה על העזרה
זה אפילו לא עובד במצב סינכרוני  :silly:
בקיצור תלך לביוס תשנה את המיכפלה תשאיר על 11.5 אבל תעלה את הFSB מ 100 ל 166 ואת הזיכרון תשנה ל 1/1 או 3/3 או כל דבר בסגנון הזה...
בדיוק.
טוב, קודם כל תודה על העזרה
שיניתי את הFSB מ 100 ל 166 בלי לשנות את המולטיפלייר ועכשיו המעבד רץ על 1.9GHz:
זה המצב התקין??
עשיתי בנצמרק עם SANDRA לפני ואחריי כדיי לראות את ההבדל בבצועים :
מתי שזה היה על 100:
ALU = 4290 MIPS
FPU = 1767 MFLOPS
אחריי שהעלתי:
ALU = 7321 MIPS
FPU = 3014 MFLOPS
כן זה המצב התקין :)
עכשיו תתחיל לעשות OC :smile1:
כן.....
אבל עכשיו שהמהירות גבוהה בהרבה המעבד מגיע לטמפ' של 51, מקודם זה היה 41,
להחליף קרור או שזה נורמלי?
תראה איזה הבדל בביצועים...
אתה יכול אפילו לעשות אוברקלוק לאיזה באס 200....
שמת את הזכרונות על סינכרוני? עכישו גם הם עובדים ב 166?
51 מעלות זה סביר , אנשים , למה לו לעשות OC , עזבו את המעבד המסכן בשקט.
הייתי מנסה איזה OC אבל לא נראה לי שאפשר להגיע לבצעים גבוהים עם זכרונות וקרור ג'נרי.
בכל אופן תודה על העזרה.... ;)
