מה אתם חושבים על המחשב שלי יש לי אותו כבר שנה ושלושה חודשים.
זה המפרט שלי רציתי לראות מה אתם חושבים עליו.....
האם יש מקום לשיפור(ותיהיו ריאליסטים).
Processor
Model : Intel® Pentium® 4 CPU 2.40GHz
Speed : 2.41GHz
Performance Rating : PR2652 (estimated)
Type : Standard
L2 On-board Cache : 512kB ECC Synchronous ATC (8-way sectored, 64 byte line size)
Mainboard
Bus(es) : ISA AGP PCI IMB USB i2c/SMBus
MP Support : 1 CPU(s)
MP APIC : Yes
System BIOS : American Megatrends Inc. V1.0
Mainboard : MICRO-STAR INC. MS-6728
Total Memory : 255MB DDR-SDRAM
Chipset 1
Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface
Front Side Bus Speed : 4x 134MHz (536MHz data rate)
Total Memory : 256MB DDR-SDRAM
Memory Bus Speed : 2x 167MHz (334MHz data rate)
Video System
Monitor/Panel : Plug and Play Monitor
Adapter : NVIDIA GeForce FX 5200
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : Maxtor 6E040L0
CD-ROM/DVD : ATAPI CD-ROM 52XMax
CD-ROM/DVD : ATAPI CD-RW 52XMax
CD-ROM/DVD : Generic STEALTH DVD SCSI CdRom Device
Logical Storage Devices
1.44MB 3.5" (A:) : N/A
12345678901 (C:) : 34.2GB (898MB, 3% Free) (FAT32)
Hard Disk (D:) : 4.1GB (638MB, 15% Free) (FAT32)
Terayon_tj7xx (E:) : 13MB (0MB, 0% Free) (CDFS)
CD-ROM/DVD (F:) : N/A
CD-ROM/DVD (G:) : N/A
CD-ROM/DVD (H:) : N/A
CD-ROM/DVD (I:) : N/A
Peripherals
Serial/Parallel Port(s) : 2 COM / 1 LPT
USB Controller/Hub : Intel® 82801EB USB Universal Host Controller - 24D2
USB Controller/Hub : Intel® 82801EB USB Universal Host Controller - 24D4
USB Controller/Hub : Intel® 82801EB USB Universal Host Controller - 24D7
USB Controller/Hub : Intel PCI to USB Enhanced Host Controller - ICH5
USB Controller/Hub : Intel® 82801EB USB Universal Host Controller - 24DE
USB Controller/Hub : USB Root Hub
USB Controller/Hub : Unknown Device
USB Controller/Hub : Terayon Cable Modem (WDM)
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : PS/2 Compatible Mouse
Communication Device(s)
Device : NetoDragon 56K Voice Modem
Printers and Faxes
Model : hp deskjet 3820 series (2)
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600
Network Services
Network Drivers Enabled : Yes
מחשב ככה... כרטיס מסך הייתה לי הרעשה שזה יהיה זה..
קודם כל אם אתה רוצה להריץ את דום 3 כדאי לך להוסיף עוד 256MB
חשבתי להוסיף אבל אמרתי לעצמי בינתיים אני מסתדר ולא כל כך בא לי על משחקים עכשיו אז עדיף לחכות.
אני מצפה לעוד תגובות ענייניות יותר...
מחשב בסדר גמור....
למשחקים הייתי מוסיף עוד זכרון ומחיליף כרטיס מסך....
כמה הוא עלה לך בזמנו?
מחשב בסדר גמור....
קניתי אותו ב4000 באיבורי מחשבים(חנות באמת זולה מומלץ לכולם).
כוללללל הכל מסך מקלדת עכבר רמקולים איכותיים ומפרט שבזמנו גם היה מצויין..
איבורי ?!!?!?!מומלץ לכולם.....אני בספק זה דיי חרא של חברה אם חרא של שירות וחרא של מפרטים....יצאת בפוקס....
