Drivers Problem.
Ok, i have Creative Audigy 2 ZS and realtek OB sound card.
two days ago i made format for C: and now there is one application in the "Device Manneger" that didnt get update.
that file is for the Realtek, when i am updating it, it starts to make problems and the computer got stuck, what should i do ?
Stay with the Realtk while he is not updated ?
Thanks alot! :)
download a new driver maybe ???
www.realtek.com.tw
what makes you think that the *unknown device* that didnt got updated is the realtek ???
why dont you just disable the onboard sound from the bios ???
the audigy2 zs is way better
you can also disable it from the device manager.
in face, it's better to disable similar devices which are not in use in your system like multiple network cards or something like that, so you won't have resource collsions.
but fuck the ob card, you dont need it if you got the audigy 2
I agree, disable it through the BIOS and get rid of it, you have a way better sound card.
Goodluck and Have a nice day.
Thanks everybody!
I just forgot to disable it from the bios!
Thanks again! :)
